Is it safe to remove the middle layer out of an OEM headgasket?
Old Jun 5, 2003 | 11:33 AM
WAFFLES's Avatar
Default Is it safe to remove the middle layer out of an OEM headgasket?
I have an extra headgasket laying around and I have been thinking of removing the middle layer to bring more compression. I know it's possible to remove the layer, but will the headgasket still seal after installed?
Also, about how much will this raise the compression?
Any help would be great, and also how do you go about removing the middle layer?
Old Jun 5, 2003 | 11:40 AM
skribblah's Avatar
Default Re: Is it safe to remove the middle layer out of an OEM headgasket? (WAFFLES)
it would more than likely up your compression like .01% and wouldn't be worth the risk of having a leaky or defective headgasget. just get a higher quality thinner one... i think spoon makes one.
Old Jun 5, 2003 | 11:43 AM
WAFFLES's Avatar
Default Re: Is it safe to remove the middle layer out of an OEM headgasket? (skribblah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skribblah &raquo;</TD></TR><TR><TD CLASS="quote">it would more than likely up your compression like .01% and wouldn't be worth the risk of having a leaky or defective headgasget. just get a higher quality thinner one... i think spoon makes one.</TD></TR></TABLE>
At the risk of sounding like a complete moron, I HEARD that the Spoon 2 layer headgasket is nothing more then an OEM headgasket with removed layer. Correct me if I'm wrong.
Old Jun 5, 2003 | 11:55 AM
SlowPoke's Avatar
New User
I've heard of a good amount of people just using the middle layer alone. You have to prep it right though otherwise it won't last long. I think some guys mentioned using some sort of copper spray on it before using it?? I'm not too sure but do a search for headgasket or some sort. There is a bunch of threads about splitting the stock headgasket. Good luck
Old Jun 5, 2003 | 12:13 PM
WAFFLES's Avatar
Default Re: Is it safe to remove the middle layer out of an OEM headgasket? (SlowPoke)
Thanks...I'll check the search real quick.
Old Jun 5, 2003 | 12:36 PM
Hybrid Invasion's Avatar
dude, dont mess with your headgasket, just buy a lower or higher compression headgasket, whichever way you're trying to go. Blowing a headgasket is WAY too big of a chance to take because of trying to mix and match.
Old Jun 5, 2003 | 06:12 PM
Mr Hammond's Avatar
a/k/a Jomo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WAFFLES &raquo;</TD></TR><TR><TD CLASS="quote">
At the risk of sounding like a complete moron, I HEARD that the Spoon 2 layer headgasket is nothing more then an OEM headgasket with removed layer. Correct me if I'm wrong.</TD></TR></TABLE>
I will. You are. Don't look for compression in a head gasket. Mill the head or look elsewheres. Not even worth the risk.
Old Jun 5, 2003 | 06:32 PM
B16GSR's Avatar
Default Re: Is it safe to remove the middle layer out of an OEM headgasket? (Mr Milano)
there is nothing wrong with removing the middle layer, roughly 5 thou which is estimating .05 in compression
hell i have built a couple of b16s using only the bottom layer(black layer) and have never had a single headgasket leak.
one has roughly 35k miles on it, so no big issue
i trust stock honda gaskets more than any other
that is my input
BTW you can not add material back to a head when you mill it, i would much rather take it out of the gasket. the max i would ever mill a head is 20 thou and just for servicing and a mild compression bump
Old Jun 5, 2003 | 06:37 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: Is it safe to remove the middle layer out of an OEM headgasket? (B16GSR)
Exactly my point. Not really worth the mild compression bump. Save up build the motor have a set compression point and find the piston, bore, head combo etc...to acheieve that. I am not a fan of milling heads or thing head gaskets really.
Old Jun 5, 2003 | 07:13 PM
hybridEj6's Avatar
yeah i think it would be fine if you put copper spray on it, some guy at my school said he sprayed aluminum spray paint on the gasket on the motor he supposedly has, he said its re-usable, but i dont know id just stick with factory oem, maybe mill the head a little with a single layer head gasket, should be good
Old Jun 5, 2003 | 07:34 PM
eddiecut's Avatar
Default Re: Is it safe to remove the middle layer out of an OEM headgasket? (ekayjeezer)
lip did that, ask him about how it lasted
Old Jun 5, 2003 | 07:46 PM
B16GSR's Avatar
Default Re: Is it safe to remove the middle layer out of an OEM headgasket? (eddiecut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eddiecut &raquo;</TD></TR><TR><TD CLASS="quote">lip did that, ask him about how it lasted</TD></TR></TABLE>
what happened?
Old Jun 5, 2003 | 10:18 PM
V-SPEC 1's Avatar
I've done a couple of built motor without the middle layer and had no problem whatsoever. Just make sure you spray a good amount of copper spray.
Vic
Old Jun 6, 2003 | 06:38 AM
B16GSR's Avatar
Default Re: Is it safe to remove the middle layer out of an OEM headgasket? (boostedb20vtec)
i have never coppersprayed one that i took the layer. and i had no problems, copper spray can just build that layer back on as well as help with the sealing
lude98SH
Feb 8, 2007 08:49 AM
mr abstract
Sep 21, 2006 03:03 PM
91integraLSVTEC
Aug 14, 2006 04:06 PM
tomlinson619
May 26, 2006 08:01 AM
JDMvtecDRAGSTA
Mar 26, 2002 01:55 PM
