MTF through VSS hole??
Old Jun 5, 2003 | 11:23 AM
REDBARON's Avatar
Default MTF through VSS hole??
Hey guys, I'm trying to find out if you can fill the tranny with MTF through the VSS hole. The hole you put the cable into the tranny. I know the proper way to do it, and everything, but I was wondering if it's possible to do it through there. That way I know if it's filled up all the way. For some reason I don't think it fills up all the way with the regular way.
Thanks guys.
Old Jun 5, 2003 | 11:36 AM
raene's Avatar
Default Re: MTF through VSS hole?? (REDBARON)
I know what you mean and I worry about this also... I'm pretty sure there's a large bolt on the top of the transmission that you can remove and fill through instead of using the side hole. Just open the side hole so you can see when the oil starts to leak out, and then remove the bolt on top of the transmission and fill through that hole instead. I'm not sure if using the VSS would work also, but I'm pretty sure this bolt I'm speaking of is more accessible.
Old Jun 5, 2003 | 11:39 AM
REDBARON's Avatar
Default Re: MTF through VSS hole?? (raene)
I'm not sure what bolt you're talking about. Would you be able to show a pic? Or maybe a better description on where the bolt is at?
Thanks.
Old Jun 5, 2003 | 01:09 PM
mr. carpenter's Avatar
jack the car up on the passenger side and fill it. put plug in before you lower car and fluid will be over necessary level
Old Jun 5, 2003 | 01:12 PM
REDBARON's Avatar
Default Re: MTF through VSS hole?? (mr. carpenter)
Damn!
That's a good idea. I never thought of that.
Thanks for the idea Mr. Carpenter
Old Jun 5, 2003 | 01:22 PM
glad to help
Old Jun 5, 2003 | 01:26 PM
RCautoworks's Avatar
Here is the one bolt you could use, if your have a b series tranny.
Old Jun 5, 2003 | 01:30 PM
REDBARON's Avatar
Default Re: MTF through VSS hole?? (90blackcrx)
I do have a B series. Thanks for the pic.
Old Jun 5, 2003 | 01:33 PM
Ef Whore's Avatar
You might not "think" its filled up the other way but it is....fill it till it runs out. Thats just the way its done.
Old Jun 5, 2003 | 01:43 PM
raene's Avatar
Default Re: MTF through VSS hole?? (Ef *****)
That's the bolt I was looking for
Old Jun 5, 2003 | 01:54 PM
ViperRedCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Here is the one bolt you could use, if your have a b series tranny.
pretty tranny
Old Jun 5, 2003 | 02:10 PM
Neukin's Avatar
Default Re: MTF through VSS hole?? (ViperRedCRX)
my s1 tranny has a hole in the top, all i do is remove this rubber cap and then fill. dont you guys have that too...?
Old Jun 5, 2003 | 02:13 PM
raene's Avatar
Default Re: MTF through VSS hole?? (toyosupr)
Bolt, hole... to me for not knowing the difference....
Old Jun 5, 2003 | 04:43 PM
ScottEK's Avatar
Someone commented about being over necessary level, doesn't the oil come out of areas if you fill it too much?
EDIT: I'm not talking about it draining out showing you that it's filled, I'm talking about if you fill it too much it's supposed to come out of the flywheel inspection plate and other areas.
Old Jun 5, 2003 | 05:55 PM
Default Re: MTF through VSS hole?? (beta13)
not if the casing is totally sealed as it should be
Old Jun 5, 2003 | 06:20 PM
Artful Dodger's Avatar
If you overfill it shifting feels like you're pushing through more fluid, just fill it the normal way and you and your car will be happy
Old Jun 5, 2003 | 06:21 PM
Fobtions's Avatar
i always use the vss hole. no need to mess with pumps or waiting drop by drop with the rubber capped hole.
Old Jun 5, 2003 | 07:31 PM
Blaze45's Avatar
Brrraaaap!
Default Re: MTF through VSS hole?? (Fobtions)
The bling factor on that tranny is sweet! how'd you get it so nice lookin&gt;?
Blaze
Old Jun 6, 2003 | 05:41 AM
REDBARON's Avatar
Default Re: MTF through VSS hole?? (Blaze45)
So you can fill the tranny from the hole on top of the tranny with the black rubber cap??? I wondered what that was for.
Old Jun 6, 2003 | 08:54 AM
turbo sol's Avatar
i just drain the tranny and then use the back up sensor hole to fill the tranny back up. you can get the capacity specs from many manuals.
Old Jun 6, 2003 | 10:12 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REDBARON &raquo;</TD></TR><TR><TD CLASS="quote">So you can fill the tranny from the hole on top of the tranny with the black rubber cap??? I wondered what that was for.</TD></TR></TABLE>
Its actually a breather hole for the trans. Don't know how much the tranny can breath though with that rubber cap on top.
Old Jun 6, 2003 | 10:22 AM
Ef Whore's Avatar
Why dont you just do it like Honda says? 2 qts. through the fill hole....oh wait Honda doesnt know what they're talking about.
Old Jun 6, 2003 | 10:30 AM
REDBARON's Avatar
Ef *****, calm down. I do know how to fill it like Honda say's. It's just that it starts seeping out before I put the complete amount. Like half a qt. before. I'm not trying to over fill it, I'm just trying to find a better way to put the exact amount that the Helms says to put in. That's all.
So it is ok to fill it through the breather hole, right?
Old Jun 6, 2003 | 12:07 PM
Neukin's Avatar
efwhore i dont remember Honda saying throwing turbos on and upgrading the **** out of their engines was cool, but looks like we do it anyway!!! be alittle open minded filling in that breather hole is cool, i do it and it works, just remove that plug on the side to let the air out when you fill in the breather. also you might not be able to fill the tranny with the same amount as helms says because of some fluid that might not come out when draining because of the way the tranny is positioned?? thats my guess.
Old Jun 6, 2003 | 01:53 PM
iwouldHITit's Avatar
you can use the vss hole..just take out the whole vss and pour in your MTF..i always do this cause my trans casing is crack so i need to refill it like every other week
