Sway Bar Question...
Yes, it is much better and you dont have to worry about subframe tearout like the ST bar has caused on a LOT of cars.
Yes, with the Beaks kit you need to drill 2 holes. It litteraly took me less then 5 minutes to measure and drill both holes. Just use the actual Beaks plates to mark the new holes, move them out of the way and drill.
Yes, one hole on each side. You already have holes to bolt up an si rear sway bar but the itr is a lot bigger and the holes need to be wider. I have had the itr bar with beaks kit on my car for almost two years and the subframe is perfect. This isnt from just driving around on the street either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonyXcom »</TD></TR><TR><TD CLASS="quote">Yes, it is much better and you dont have to worry about subframe tearout like the ST bar has caused on a LOT of cars.</TD></TR></TABLE>
luv mine. one of the best suspension mods you can do
you'll definitley feel the difference
dgdarien
10
Mar 30, 2003 01:09 PM
