b16 almost starting making poping noise??
ok guys i have spark and fuel now its almost starting its making a poping noies when i crank it.. my friend says he seen some one do a swap and it was doing the same thing and then it finaly started what should i do.. my battery is almost dead so im gonna charge it tomorrow and try to crank it again do you guys have any sugesstions
Check your spark plug firing order. I recall when I did my swap the order was all wrong, and I did it according to a book. Turns out it was the wrong book. Mine also made sputtering and popping noise until I got the firing order right, then it started right up and has been running like a champ ever since.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrRoboto »</TD></TR><TR><TD CLASS="quote">Check your spark plug firing order. I recall when I did my swap the order was all wrong, and I did it according to a book. Turns out it was the wrong book. Mine also made sputtering and popping noise until I got the firing order right, then it started right up and has been running like a champ ever since. </TD></TR></TABLE>
This is true, mine did the same thing. Rayn
Good advice- my swap was doing the same thing b/c of the plug wire order & my dizzy wiring....
slic187
Jun 20, 2006 08:13 AM
accordisslow
Jan 5, 2006 07:09 PM
