what struts for a slammed car????????
Old Jun 4, 2003 | 11:36 PM
Synergy001's Avatar
Default what struts for a slammed car????????
what kind of struts would you guys suggest for a slammed car? i am looking for new struts but i dont want to spend a lot of money if it ends up blowing out. i have proactive coilovers on, but the perch seized up on me and now i cant adjust it so i need some struts that wont blow on slammed cars. TIA
Old Jun 4, 2003 | 11:48 PM
SpoonFedHatch's Avatar
no matter what struts you end up going with, you'll still have the huge gap between the spring and the top perch, which will give the car ZERO suspension travel and ZERO ride comfort.....
if you are looking for an affordable alternative, just go with some GC coilovers, or with some used eibach sportlines (2.5" drop) and some affordable KYB gr-2 struts
i'm using GC coilovers on GR2's, and it has plenty of travel at 2" drop, plus it allows for better handling as well
if you're still stuck on having a 3-4" drop, then go with some AGX's i guess......i wouldnt recommend it though
Old Jun 4, 2003 | 11:53 PM
Synergy001's Avatar
cool thanks...anybody else got opinions....also, who makes strut mounts that will allow more strut travel. i seen a DIY on it but i'd rather buy from a company who made it just in case the weld gives out and then ill have two holes on my hood. TIA
Old Jun 5, 2003 | 12:07 AM
Henry HA's Avatar
HAnda-Tech Member
Default Re: (Synergy001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Synergy001 &raquo;</TD></TR><TR><TD CLASS="quote">cool thanks...anybody else got opinions....also, who makes strut mounts that will allow more strut travel. i seen a DIY on it but i'd rather buy from a company who made it just in case the weld gives out and then ill have two holes on my hood. TIA</TD></TR></TABLE>
what he said ...AGX...
and why does your title still say "trail user"?...or did you want it that way?
Old Jun 5, 2003 | 12:12 AM
Synergy001's Avatar
i dont know why my title still says "trial user"...i think my friend (who is one of the administrators here on H-T) did that to mess around with my title. it's all good tho it dont bother me none
Old Jun 5, 2003 | 01:01 PM
Synergy001's Avatar
bump for the day people
Old Jun 5, 2003 | 01:37 PM
jcarothers's Avatar
not many shocks will take a slammed car... AGX's might take it.. or you could talk to a shock/strut company and get some custom ones made up and actually still ahve a warrantee, however that will cost some serious $$$
Old Jun 5, 2003 | 01:44 PM
EVIL Hx Coupe's Avatar
Default Re: (jcarothers)
I dont think KYB AGX will take that much of a drop for too long... I've heard of the blowing really easy whe you go past a 2" drop.
Old Jun 5, 2003 | 01:48 PM
tominos's Avatar
Default Re: (EVIL Hx Coupe)
kyb's warranty does not apply if the car is lowered more than 1.5 inches.
Old Jun 5, 2003 | 01:58 PM
94hondaLS's Avatar
Default Re: (tominos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tominos &raquo;</TD></TR><TR><TD CLASS="quote">kyb's warranty does not apply if the car is lowered more than 1.5 inches.</TD></TR></TABLE> how do they know if the cars been droped lower?
Old Jun 5, 2003 | 02:07 PM
AcuraEL's Avatar
I have 2 extended shocks mounts, 1", painted yellow, they go in front. I ask 50$ for both
email me yk3d@yahoo.com
Old Jun 5, 2003 | 02:45 PM
tonesdef's Avatar
Default Re: (AcuraEL)
i have agx's with gc and i'm slamed they have held up unless that is what that metal on metal sound it when i turn left but its most likely brakes.
the ride is nice but stiff but oh well
Old Jun 5, 2003 | 03:09 PM
(teh)H2OUUP2's Avatar
KYB AGX, Skunk 2 Integra Coils all the way down. Daily Driven thru Washington D.C.'s warzones.........and a roll bar and ITR sways front and rear.
Modified by JDMSir-G at 7:51 PM 6/5/2003
Old Jun 5, 2003 | 03:11 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: what struts for a slammed car???????? (Synergy001)
AGXs have little marks on the shock piston that the techs at KYB can inspect and see how low you were. That's what I've been TOLD anyway.
If you're going to be 3.5-4"+ lowered, any shock is going to bottom out, even if you have HIGH HIGH spring rates, you just can't be that low on the street and not have that happen. All shocks will die after you bottom them out too much; Koni, AGX, or whatever it is.
Best thing you could do is get shortened struts and higher mounts but then you'll be hitting your fender with your tire and run into clearance problems because you can only shorten and highten the mounts so much.
Just roll on stock shocks if you're gonna be slammed and daily drive it or you're going to be wasting a lot of money.
Old Jun 5, 2003 | 03:14 PM
EL-Driver's Avatar
Default Re: (tonesdef)
On my old 89 Honda Civic DX...
I had it dumped on R1 Crappy Coilovers and Koni Reds..total drop was 3 inches front and rear...
The ride quality was decent but not smooth, it looked good....then the passenger side axel snapped and motor blew so I sold the car
So in conclusion I would go with Koni Reds, I paid $580 cdn and $200 for the R1 coilovers..
Old Jun 5, 2003 | 03:45 PM
function83's Avatar
Default Re: (EL-Driver)
tokico blues they didn't blow out when i owned them.
Old Jun 5, 2003 | 03:59 PM
juicedricer's Avatar
Default Re: (djhatch)
if u are trying to raise it just do what i did take 2 flatheads and hammer them between the perches and hammer them loose enough and use PB blaster also.
Old Jun 5, 2003 | 04:54 PM
Synergy001's Avatar
Default Re: (juicedricer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by juicedricer &raquo;</TD></TR><TR><TD CLASS="quote">if u are trying to raise it just do what i did take 2 flatheads and hammer them between the perches and hammer them loose enough and use PB blaster also.</TD></TR></TABLE>
the proactive coilover only has one perch...any other suggestions?? anybody??
Old Jun 5, 2003 | 04:55 PM
Synergy001's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AcuraEL &raquo;</TD></TR><TR><TD CLASS="quote">I have 2 extended shocks mounts, 1", painted yellow, they go in front. I ask 50$ for both
email me yk3d@yahoo.com</TD></TR></TABLE>
did you makes those extended shock mounts? got any pix? e-mail them to resteban1467@msn.com. i found some that ground control made and they are $75 for two.
Old Jun 5, 2003 | 05:18 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
the proactive coilover only has one perch...any other suggestions?? anybody?? </TD></TR></TABLE>
pipe wrench?
Old Jun 5, 2003 | 05:25 PM
beedoublejay's Avatar
get the ground control upper pillow mounts, the increase strut travel, they should work with whatever struts you decide to go with.
Synergy001's Avatar
i think i might just get some Teins for my car. a local shop is selling the SS for $850 and the Flex for $1215. I think that its a pretty decent price. Do you guys know anywhere else thats cheaper?
Old Jun 5, 2003 | 05:26 PM
Mr. Joe's Avatar
Default Re: (JDMSir-G)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMSir-G &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
This car is beautiful
Old Jun 5, 2003 | 05:28 PM
hoya_10fintec's Avatar
I don't know what others will say but in my case, I'm using Koni reds.. a little bitchy to adjust them but those are doing good so far and they're pretty cheap... it's been almost 3 years driving everyday even in winter slammed(3.5")...
Not one blew.. I'm happy with them..
Old Jun 5, 2003 | 06:30 PM
Touch's Avatar
Default Re: what struts for a slammed car???????? (hoya_10fintec)
gcs on stock 92 cx struts.
