will integra type r pistons .25 over bore fit a b20 block? what needs to be done to make it work?
Old Jun 4, 2003 | 11:25 PM
mugensport9's Avatar
Default will integra type r pistons .25 over bore fit a b20 block? what needs to be done to make it work?
i was wondering if that would fit right in? what rods would i need to use? ls rods?
Old Jun 4, 2003 | 11:28 PM
ArinX's Avatar
Default Re: will integra type r pistons .25 over bore fit a b20 block? what needs to be done to make it work
no it wont work
edit: i thought id give more info why
the bore size is different ..84mm
Old Jun 4, 2003 | 11:40 PM
ill phil's Avatar
Yeah to bump C/R you're gonna have to get some aftermarket 84mm pistons. You can use LS/B20 rods with certain pistons, but as with most aftermarket you may have to go aftermarket rods too.
To add on to the last guys- your .25 overbore only takes them to 81.25
Old Jun 5, 2003 | 01:42 AM
AussieK24's Avatar
Yeah they fit but the rattle gets annoying hehehe
As he said 81mm vs 84mm
Old Jun 5, 2003 | 02:10 AM
are there any type r pistons that i can get that fit the b20 block?
Old Jun 5, 2003 | 02:22 AM
ill phil's Avatar
No, as previously stated all B16/B18 are 81mm. B20 has a 84 mm bore. No a Type R piston will not work.
Old Jun 5, 2003 | 02:23 AM
AussieK24's Avatar
NO. Type r pistons are 3mm too small. You might be able to get type r style pistons from an aftermarket supplier.
Old Jun 5, 2003 | 06:23 PM
Mr Hammond's Avatar
a/k/a Jomo
Well you could get some Arias or JE's off the shelf and range from about 12-14.5:1 compression, but they aren't Type R pistons. Probably junk anyways.
Old Jun 6, 2003 | 03:45 AM
Westrock2000's Avatar
Running JE 84mm 12.5:1 in a B20B. Actually about 12:1 with an LS head. I think the compressions a little to high. Hasn't overheated yet (Texas), but I can't wide open throttle without it starting to detonate. I think I'll go to 11.5:1 to see how that is. Also, at least in my case, they are only rough for maybe the first 5 seconds. Some poeple say they are real loud since the silicon level is low and they contract/expand...but they seem ok to me.
Old Jun 6, 2003 | 07:19 AM
Civichatch2k's Avatar
Just get some Wiseco pistons or something like that, the ITR are too small for that block. B20's are 84mm.
Old Jan 14, 2012 | 11:47 AM
91 Ac's Avatar
Well my Ls has type r pistons and the compression is higher than stock, been driving it hard for over 2 years now and no problems. A well known and respectable mechanic named David Polk build it so as far the bore size goes I'd never asked'em about.
Old Jan 14, 2012 | 11:54 AM
93egSLEEPER's Avatar
I saw this thread title and LOL'd, then opened it to see it was a bump from 2003...made my day.
Thanks for the laugh and good bump buddy. This thread isn't 9 years old... (sarcastic)
#iremebermyfirstdayonHT lulz
Old Jan 14, 2012 | 12:35 PM
00Red_SiR's Avatar
All Motor Mentor
good god.....people should get reprimanded for such rediculous actions.... not only is the thread 9 years old and before RS machines had their ITR B20 pistons out, but an LS is an 81mm bore!!! C'mon 91 Ac...
Racer9999
Feb 3, 2016 10:17 PM
CeNCaL-DA9
Aug 16, 2007 04:11 PM
ALLMOTOR CRX
Mar 13, 2007 01:47 PM
JDM97EK
14
Mar 7, 2006 07:44 PM
jdm92teg
Nov 11, 2004 09:12 AM
