TDC Problem
Old Jun 4, 2003 | 01:24 PM
Ronin Panda's Avatar
Default TDC Problem
ok i put my block/head back together and set everything to TDC..got the timing belt on and got the motor in the car..went to put the dizzy on and the dizzy rotor is pointing UP and not pointing to the #1 cylinder wire...whats the dealyo?
i pulled the dizzy and tryed turning it to face the #1 cylinder but it only goes in one way..so that didnt work.
again: everything on TDC except for the dizzy rotor..its pointing UP.
maybe i got the intake cam in wrong?? (DOHC ZC)
what else could it be?
thanks
Old Jun 4, 2003 | 02:02 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: TDC Problem (Touge Panda)
the cam is probably 180 degrees out..
the cam spins two revolutions to the crank spinning one revolution..
Old Jun 4, 2003 | 03:40 PM
Default Re: TDC Problem (88DXCRX)
which is the number one plug wire on the dizzy?
TOP=#1????
Old Jun 4, 2003 | 06:59 PM
Blaze45's Avatar
Brrraaaap!
I thought it was 3 oh well. Heres someone who had serious timming issues...
https://honda-tech.com/zerothread?id=521360
page down for a good laugh...
Blaze
Old Jun 6, 2003 | 10:41 AM
Default Re: TDC Problem (Blaze45)
does anyone know the spark plug gap #'s for the dohc zc?
can anyone tell me which is the number 1 cylinder on the dizzy?
i think it is the top hole in the dizzy..(the #1 cylinder wire goes from the
cylinder closest to the cam gears , and to the top hole in the dizzy)
is this correct?
what is the firing order for the dohc zc?
any timing specs i need to know for this motor? (what do i have to do in order
to set the timing?)
thanks
Old Jun 6, 2003 | 01:16 PM
anyone?
stickman78114
Feb 21, 2010 09:37 AM
adam081904
Mar 1, 2008 12:16 AM
1990si
24
Sep 22, 2006 04:40 AM
roydogg
Feb 13, 2005 11:31 AM
