swap, tranny questions
Old Jun 4, 2003 | 12:58 PM
Creepshow S60's Avatar
Default swap, tranny questions
my friend wants to put a b18b in his civic hatch. he says he wants to put in an ek si tranny. what's the benefit to this? i'm just curious, that's all. wouldn't the stock tranny be fine, or would the si tranny actually help? better gear ratios or what? it will be used on the street FYI. how about a reccomended tranny for him? wouldn't the b18b tranny be optimal? eh, i'm confused.
Old Jun 4, 2003 | 01:12 PM
Malgerus's Avatar
Default Re: swap, tranny questions (y-49CRX)
Won't work. The stock EK tranny is a D-series tranny, and the B18B is a B-series. Completely different bolt patterns, and the B trannies are physically larger. You can't use a stock tranny. What year hatch does he want to put the engine in? If it's 88-91, the best bet would be a 90-93 integra ls transmission. Don't use a B16A one unless the motor gets built to take the extra rpms.
Old Jun 5, 2003 | 08:02 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by y-49CRX &raquo;</TD></TR><TR><TD CLASS="quote">my friend wants to put a b18b in his civic hatch. he says he wants to put in an ek si tranny. what's the benefit to this? i'm just curious, that's all. wouldn't the stock tranny be fine, or would the si tranny actually help? better gear ratios or what? it will be used on the street FYI. how about a reccomended tranny for him? wouldn't the b18b tranny be optimal? eh, i'm confused. </TD></TR></TABLE> i think he meant the 00 si tranny, and not the single cam tranny. your friend will like how the car will move if he uses an si tranny, but since he'll be stuck with a 6700rpm redline i would tell him to use the ls tranny for now! if he decides to go ls/vtec or build up the ls to handle more revs, then he should use the si tranny since he'll have the revs to make the tranny work for him!
lshondaeg
May 9, 2008 11:53 AM
badblackhatch
Mar 19, 2004 07:40 PM
greebler
Sep 21, 2003 07:34 PM
boywonda
May 4, 2003 01:37 PM
MR. ARIZONA
Sep 2, 2002 02:17 AM
