is there a sensor on the very top of the throttlebody on the manifold
Old Jun 4, 2003 | 10:49 AM
preluder's Avatar
Default is there a sensor on the very top of the throttlebody on the manifold
on a jdm throttle body does both the throttle body have the sensor on the very top near where the intake goes whats that sensor called not the tps or the idle air or the thermo its the other one . whats it called?
Old Jun 4, 2003 | 10:52 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: is there a sensor on the very top of the throttlebody on the manifold (preluder)
MAP sensor
Old Jun 4, 2003 | 01:27 PM
preluder's Avatar
Default Re: is there a sensor on the very top of the throttlebody on the manifold (Boosted97Lude)
no no not that on my map sensor is on the firewal not on the throttlebody , but can that not being connected mess up the car as far as running it. Cause my car idles like crap on top of that the shop person used my original accord throttlebody front where the intake latches onto is this good or bad?
Old Jun 4, 2003 | 02:38 PM
CHK4TIX's Avatar
if you did a jdm swap, you dont used the map sensor that came connected to the IM. You use the existing one that is on the fire wall.
edit: if we are both wrong, can you post a pic of what you are talking about?
Old Jun 9, 2003 | 08:30 AM
preluder's Avatar
Default Re: is there a sensor on the very top of the throttlebody on the manifold (CHK4TIX)
tommorrthe pics will be up
T-nastyteggy
Apr 20, 2011 08:37 PM
.Hookedonhatch.
Mar 3, 2004 05:46 AM
dose
Apr 7, 2003 06:52 PM
comptechgsr2000
May 8, 2002 03:53 PM
