has anyone ever tried the crower dohc regrinds for H23?
i'm thinking about getting them. they're only $136.85 plus shipping for the straight regrinds, and i have an extra set of stock camshafts. anyone have any words of wisdom or stories to share on camshaft regrinds? thanks, del
I would not do crower re-grinds. If you are going to do re-grinds, go with Web, they are much better than crower.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jacklee »</TD></TR><TR><TD CLASS="quote">so u mean it cost $136.85 for what ever spec's you want them to grind it to? or what is straight regrinds? </TD></TR></TABLE>
2. Straight regrind- Reduced base circle allows more lobe lift. Limited spec, emphasis on top end power. Typical specs are .005" to .010" more lift, 5 to 10 degrees more duration at .050" and about 5-10 more hp depending on engine mods. You supply stock cores. May require lash caps.
