being able to rev up to 7,000 rpm's on stock crx si motor
Old Jun 3, 2003 | 10:14 PM
laosbboy's Avatar
Default being able to rev up to 7,000 rpm's on stock crx si motor
i just recently bought a 88 crx si, and da guy i bought it from said there is sumthing u can do wit da motor to be able to rev up to 7,000 rpm's wit da stock motor. i was just wondering whut is it...
Old Jun 3, 2003 | 10:19 PM
SC0TT's Avatar
Default Re: being able to rev up to 7,000 rpm's on stock crx si motor (laosbboy)
Have the ECU chipped so the fuel cut-off isnt at 6600 (wherever pm6's cut off at?). Kinda pointless anyway, there really isnt gains going past 6500 with stock internals.
Old Jun 3, 2003 | 10:24 PM
Louie B.'s Avatar
the d16a6 has a warm engine rev limiter at 7200, when it's cold, it only revs to about 6500.
I take mine to 7k all the time, but like Scott said above, with a completely stock engine it won't do any good to go past 6500.
Modified by thumpu77 at 7:51 PM 6/4/2003
Old Jun 4, 2003 | 06:46 AM
altoid's Avatar
Default Re: being able to rev up to 7,000 rpm's on stock crx si motor (thumpu77)
wasn't max hp on the a6 at 7k? and max torque at 5k?
Old Jun 4, 2003 | 06:52 AM
matt j's Avatar
Default Re: being able to rev up to 7,000 rpm's on stock crx si motor (altoid)
i have revved my chipped pm6 mpfi swapped 1.5 up to 7700rpms, i was still making a little bit of power but it wasnt enough to keep revving that high, i would say shift at 7100 if you are bouncing it off the rev limiter at 6800 on a cold start you have some issues
Old Jun 4, 2003 | 09:45 AM
91civicDXdude's Avatar
the actual rev limiter on the pm6 is 7200. Your tachometers are off, or you have a chipped ECU.
Old Jun 4, 2003 | 10:05 AM
Malgerus's Avatar
Default Re: (91civicDXdude)
I hear 88-89 have a different rev limit than 90-91.... it would also help if this guy spoke real english.
Old Jun 4, 2003 | 06:55 PM
Louie B.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude &raquo;</TD></TR><TR><TD CLASS="quote">the actual rev limiter on the pm6 is 7200. </TD></TR></TABLE>
my bad... my previous post has been edited.
my chip is stock, I just never take it over 7k
Old Jun 4, 2003 | 07:01 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (thumpu77)
I hit my revlimiter the other day..... I thought I broke something..... lol First time I ever hit it, it was cause of a missed shift...
Blaze
Old Jun 4, 2003 | 07:32 PM
IamVtec's Avatar
Default Re: (Mr. S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">I hear 88-89 have a different rev limit than 90-91.... it would also help if this guy spoke real english.</TD></TR></TABLE>
im pretty sure you could read that. Just a little slang...
Old Jun 4, 2003 | 07:39 PM
MrTodd's Avatar
Default Re: (Mr. S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. S &raquo;</TD></TR><TR><TD CLASS="quote">I hear 88-89 have a different rev limit than 90-91....</TD></TR></TABLE>
I wouldn't be surpized if they do. The '90-91s have a much more agressive fuel/timing curve than the '88-89s do. The revlimiter could be different as well, but it seems that most people agree that their PM6 can't go past 7200 - I can't remember how high my PM6 went before I chipped it...
But as far as the initial question goes - The stock D16A6 should be able to handle 7k rev's fairly easily. I did it a few times with my old A6, never had a problem.
Old Jun 4, 2003 | 10:03 PM
91sihatchback
Guest
Posts: n/a
i had to say something because iam a little wierded out by this discussion because i just bought my 91 si hatch about 3 months ago and its stock and i can rev the car to 7200 before it sputters or whatever....is there something wrong? i smoke white whenever i go from first to second sometimes,but the smoke isnt huge or anything...i changed the oil about a month ago and it quit smoking for 2 weeks then one day i reved hard and it smoked is there something wrong please help!!!!
Old Jun 4, 2003 | 10:15 PM
91sihatchback
Guest
Posts: n/a
bump can someone answer me?
Old Jun 4, 2003 | 10:20 PM
KooK's Avatar
Mustang Sally
Default Re: (91sihatchback)
Maybe you blew your headgasket? Could have cracked your head? Normally white smoke means water/antifreeze. Check your oil to see if its a light brownish muck. I'll give you a picture of what the oil would look like if that happened...
Old Jun 5, 2003 | 05:45 AM
90Zcrx's Avatar
Jesus dude, please try a search engine, I tried your specific search and came up with http://www.google.com/search?h...+clue
and
http://www.google.com/search?h...ell=1
Old Jun 5, 2003 | 08:39 AM
RacerBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by laosbboy &raquo;</TD></TR><TR><TD CLASS="quote">i just recently bought a 88 crx si, and da guy i bought it from said there is sumthing u can do wit da motor to be able to rev up to 7,000 rpm's wit da stock motor. i was just wondering whut is it... </TD></TR></TABLE>
I you sure you can drive that car? You may be too young considering your grammar. lol jk
Old Jun 11, 2003 | 02:40 PM
88rexdxa6ed's Avatar
Default Re: being able to rev up to 7,000 rpm's on stock crx si motor (RacerBoy)
i take my si to 7500 all the time
Old Jun 11, 2003 | 03:01 PM
91civicEX's Avatar
i take my mpfi d15 to 7200 at least once a day
Old Jun 11, 2003 | 03:37 PM
Iceycrx's Avatar
Default Re: (91civicLX)
I had a chipped 89 si motor and i rev'd to 8k, didn't feel safe doing that all the time and decided to just shift at 7,7.5k
Old Jun 11, 2003 | 04:59 PM
keebler65's Avatar
Default Re: (Iceycrx)
i revved my D16A6 to the redline all the time and never had issues with it. it was all stock. hondas are built to be revved that high. the rev limiter is a safety device to keep ricers from revving higher than it is built for.
Old Jun 11, 2003 | 05:47 PM
Broken Gearbox's Avatar
Default Re: (keebler65)
yea my friend just swapped in an A6 and he brings it up to 7200ish all the time..i think thats when the rev-limiter kick in...i think hes gonna get a PG7 ecu...i heard you could bring it up to 7500??
Old Jun 11, 2003 | 06:43 PM
bluecrxsi's Avatar
id like to get rid of the 8400 rev limiter in mine-cause was still pulling hard. but i know that i have to chip the ecu and when i do ill dump that low 112mph governor on the pr3.
Old Jun 11, 2003 | 07:35 PM
1RMDave's Avatar
On both my 90 crx si and my 90 civic si i would rev to just over 7000 with everything stock except iceman intake. And i raced quite a bit. Did just fine. Pulled all the way too. goal was to get it as close to rev limiter without actually hitting it as that would slow my down.
Old Jun 11, 2003 | 07:42 PM
DJ_SaNdOz's Avatar
Default Re: being able to rev up to 7,000 rpm's on stock crx si motor (1RMDave)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1RMDave &raquo;</TD></TR><TR><TD CLASS="quote">On both my 90 crx si and my 90 civic si i would rev to just over 7000 with everything stock except iceman intake. And i raced quite a bit. Did just fine. Pulled all the way too. goal was to get it as close to rev limiter without actually hitting it as that would slow my down.</TD></TR></TABLE>
me too. isn't fuel cutoff around 7200?
Old Jun 11, 2003 | 07:58 PM
Default Re: being able to rev up to 7,000 rpm's on stock crx si motor (DJ_SaNdOz)
whats the rev-limit on the PG7?
