will a stock b16a head handle 9000 rpms?
Old Jun 3, 2003 | 10:07 PM
vtec_racer_2kgsr's Avatar
Default will a stock b16a head handle 9000 rpms?
I have a B18c5 block and ECU and I have a B16a off a 99 Si will the si head handle 9000 rpms if not what should I get to be safe?
Old Jun 3, 2003 | 10:10 PM
SikofFalln's Avatar
Default Re: will a stock b16a head handle 9000 rpms? (vtec_racer_98GSR)
Not for long...
IWearMyKswiss's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec_racer_98GSR &raquo;</TD></TR><TR><TD CLASS="quote">I have a B18c5 block and ECU and I have a B16a off a 99 Si will the si head handle 9000 rpms if not what should I get to be safe? </TD></TR></TABLE>
it might but i would recommend new springs and retainers
Old Jun 3, 2003 | 10:14 PM
Default Re: will a stock b16a head handle 9000 rpms? (WiDeBoDyEK)
thats it springs and retainers?
skunk2?
Old Jun 3, 2003 | 10:18 PM
JaeOne3345's Avatar
are you gonna be making power at 9k?
Old Jun 3, 2003 | 10:19 PM
Newman's Avatar
New User
If you plan to rev up to 9000 all the time, I'd consider swapping out the LMAs for some Type R ones.... I've seen too many old B16 LMAs go out and collapse, sometimes causing the cams to break in half in the head.
Old Jun 3, 2003 | 10:24 PM
Default Re: will a stock b16a head handle 9000 rpms? (Newman)
lmas?
Old Jun 3, 2003 | 10:26 PM
Default Re: will a stock b16a head handle 9000 rpms? (JaeOne3345)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JaeOne3345 &raquo;</TD></TR><TR><TD CLASS="quote">are you gonna be making power at 9k?</TD></TR></TABLE>
I dont think so but if I miss a gear I will be up there right
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec_racer_98GSR &raquo;</TD></TR><TR><TD CLASS="quote">lmas?</TD></TR></TABLE>
TypeR "lost motion assemblies."
are you going to be upgrading your cams as well? If you're running stock cams, or TypeR cams, you'll stop making power well before 9k, so it's wasteful
Old Jun 3, 2003 | 10:31 PM
Newman's Avatar
New User
I dont think so but if I miss a gear I will be up there right</TD></TR></TABLE>
I've hit a 10,500 rpm rev-limiter before, quite a few times when my damn clutch cable wasn't adjusted properly in my old LS/VTEC CRX.... 4 times in one night of racing (don't ask) but if your parts are in decent shape/condition, then hitting 9000 on occasion/accident won't kill anything... most of the time.
If you're really worried about over revving, spend money elsewhere to envoke a lower rev-limit, either by an ECU chip or with a VTEC/speed controller module.
Old Jun 3, 2003 | 10:33 PM
Default Re: will a stock b16a head handle 9000 rpms? (rodrez)
I dont plan to rev that high Im planning to rev8000-8400max but the ECU go's to 9000 so if I miss a gear I'll be at 9000
Old Jun 3, 2003 | 10:34 PM
Unsung's Avatar
MSD ignition box is always a good option too, if you need to set a revlimit.
so will a stock si head make power at 8300?or even 8400?
Old Jun 3, 2003 | 10:39 PM
SpoonFedHatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec_racer_98GSR &raquo;</TD></TR><TR><TD CLASS="quote">so will a stock si head make power at 8300?or even 8400?
no
your car will be screaming, yet it will not be going anywhere
Old Jun 3, 2003 | 10:41 PM
Newman's Avatar
New User
You're asking the question wrong. You should ask if the stock Si head will handle power at 8300+ with the proper setup, and yes it can, and that is mostly determined by the type of camshafts that you are using in the head. If you leave the stock B16 cams in the head, then most likely no, you will not have any power up that high, but only strapping your car onto the dyno and seeing what your peak HP is will only tell you where your car is topping out at (and that should be your shift point as there's no point to go any higher).
Old Jun 3, 2003 | 10:42 PM
function83's Avatar
8500 no more
Old Jun 3, 2003 | 10:43 PM
Unsung's Avatar
Default Re: will a stock b16a head handle 9000 rpms? (djhatch)
Mine starts losing breath at 8500 with CTR cams.
Old Jun 3, 2003 | 10:49 PM
Default Re: will a stock b16a head handle 9000 rpms? (Unsung EM1)
so I should set the redline to stock si 8000?
Old Jun 3, 2003 | 10:54 PM
Unsung's Avatar
For now, yes.
Old Jun 3, 2003 | 11:32 PM
Mr.JDM.Parts's Avatar
I taped a valve at 9600 RPM on a 96 B16a3 with 63k miles on it. Only mods were Skunk2 ECU, AEM Intake, VAFC, DC 4-1 Header, FPR, and fuel rail. I would only take it to 8,500-9000 if I were you. But DONT DO IT ALL THE TIME!!! That was my problem
Old Jun 4, 2003 | 03:54 AM
Prevail's Avatar
No limiter is gonna save you when you miss a gear shifting at 8500 RPM. A limiter will only help you if you aren't watching your tach and attempt to accelerate past that specific point.
Once you miss a downshift at 8k, its all in the tranny's hands. Cutting off fuel won't stop the tranny from spinning the engine to its impending doom.
Old Jun 4, 2003 | 05:35 AM
PupaScoopa's Avatar
Default Re: will a stock b16a head handle 9000 rpms? (SpoonFedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonFedHatch &raquo;</TD></TR><TR><TD CLASS="quote">your car will be screaming, yet it will not be going anywhere</TD></TR></TABLE>
There are a lot of good reasons to have some over-rev head room and not all of them involve making power above the engine's peak. Once you cross the peak and continue to accelerate, the engine doesn't just fall flat and "...will not be going anywhere."
I've been in numerous instances in an autocross when I'm in first gear and it's better to leave it instead of upshifting knowing that I'll have to downshift again about 1 to 2 seconds later. Being able to safely over rev doesn't necessarily mean the goal is to make power.
Think about it! (&lt;- say that slow and drawn out :-)
Old Jun 4, 2003 | 06:26 AM
B18C5-EH2's Avatar
Former Moderator
Loved
I seriously doubt that a stock cammed B16A head will make any extra power past 8100rpm or so.
Hell my B18C5 started dropping off right at 8000rpm on the dyno.
Old Jun 4, 2003 | 06:48 AM
137's Avatar
137
Default Re: will a stock b16a head handle 9000 rpms? (B18C5-EH2)
just to say it makes power at that rpm costs more money where as it could be spent more wisely utilizing the lower end of the tq and hp band imo.
Just because you saw a b16b from spoon in an option video hit 10k rpm's doesnt mean thats practical for street races or help you beat a gsr with 10 more whp and tq than you.
Old Jun 4, 2003 | 08:39 AM
NoCarBoy's Avatar
Default Re: will a stock b16a head handle 9000 rpms? (137)
get a complete valvetrain (valves, springs, retainers) from spoon or toda or even jun. and cams would help you make power all the way to 9000.
