ok, this is stupid, but...
Old Jun 3, 2003 | 10:02 PM
Malgerus's Avatar
Default ok, this is stupid, but...
Can you guys give some tips on how to seal up a hole on the bottom of the stock muffler? I can't afford my exhaust system yet, so I want to go ghetto and fix it with something homemade. I tried duct tape and pop cans, but it blew out. The Crappy tire muffler sealer kit didn't work either. Any tips?
Old Jun 3, 2003 | 10:05 PM
Louie B.'s Avatar
Default Re: ok, this is stupid, but... (Mr. S)
Just get a $10 generic "turbo" muffler and some clamps from your local auto parts store.
I made the mistake of going to my local muffler shop for a "temprary fix" until I could get the HKS system I wanted.... $200.00 later I got an "econo" muffler and all new 1 7/8 crush bent pipes because "the old ones were just too rusted out" and when he put the new pipes in, he left the resonator out so now my car sounds like sh@@!
Old Jun 3, 2003 | 10:06 PM
boosted_zc's Avatar
do u have or have access to a welder?? Build a weld up to close the hole
Old Jun 3, 2003 | 10:07 PM
Malgerus's Avatar
Default Re: ok, this is stupid, but... (boosted_zc)
Meh, those mufflers are like 30 bucks here, and i don't have access to a welder. JB weld a piece of metal on maybe???
Old Jun 3, 2003 | 10:39 PM
Redline130's Avatar
What about that aluminum tape stuff to repair exhaust leaks? I don't know how well it would work, but the stuff is pretty cheap. Might be worth a shot.
Old Jun 3, 2003 | 11:26 PM
matt j's Avatar
Default Re: ok, this is stupid, but... (Redline130)
maybe even like some header wrap might work
Old Jun 3, 2003 | 11:51 PM
crxforum's Avatar
Default Re: ok, this is stupid, but... (matt j)
For a real temp fix do what I did. Take a piece of metal, a ball peen hamer, and a aluminum baseball bat. Then take the metal and shape it to the shape that you want over the bat with the hammer. Then if you can go to the local hardware store and get those metal clamps that you can tighten with a flat head screwdriver. Then put the metal on there, clamp it down and test out how quiet it is. If it is still loud then go and get some high temp sillicone and go around the edges of the metal plate and go crazy. Fill in all the corners and edges with a huge **** load of sillicone. It should be fine for about a week or so.
CRX Forum
Shaguar47
May 11, 2006 05:59 PM
winnerpl
Mar 29, 2006 09:29 AM
Type Wah
Dec 20, 2005 11:11 AM
ibe2fly
May 12, 2004 06:00 PM
steve_s
Jan 19, 2003 04:59 PM
