new to crx, need help
Old Jun 3, 2003 | 07:55 PM
that_guy's Avatar
Default new to crx, need help
well my 90 integra has been declared a total loss and i am looking to purchace a crx. in my teg i have a b16a with some work done to it and i am looking to swap it into a crx. Im told that ideally i should get an 88 to 91 si to make the swap as easy as possible. Im also going for an (90-91 only i think) si because id like to have disk brakes. But if i am not able to get an si, does the HF wire up the same? and what kind of work am i looking at to swap my disk brakes from my integra onto the crx? I know a guy that runs a honda shop who says he will install the motor with mounts for 1000, that a good deal? thanks for your help.
Old Jun 4, 2003 | 02:48 AM
that_guy's Avatar
Default Re: new to crx, need help (that_guy)
things move fast on these forums dont they
Old Jun 4, 2003 | 07:24 AM
REDBARON's Avatar
Swapping out the rear disk from the Integra to the CRX is not that hard at all. They only thing you will need is the 90-91 CRX Si e-brake cables. Other than that it's a direct fit. The HF and Si model CRX's are what you should look for. They will work the same for wiring issues. I'd personnally go with a HF to save some weight and essentially make your car quicker. Plus you have the Teg disk brakes you can add to the car. 1000 is not too bad considering he's going to provide you with the mounts, but it really depens on your location. I'd expect it to be cheaper in Cali, but who knows.
Old Jun 4, 2003 | 07:48 AM
Mr Furball's Avatar
Default Re: new to crx, need help (REDBARON)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REDBARON &raquo;</TD></TR><TR><TD CLASS="quote">Swapping out the rear disk from the Integra to the CRX is not that hard at all. They only thing you will need is the 90-91 CRX Si e-brake cables. Other than that it's a direct fit. The HF and Si model CRX's are what you should look for. They will work the same for wiring issues. I'd personnally go with a HF to save some weight and essentially make your car quicker. Plus you have the Teg disk brakes you can add to the car</TD></TR></TABLE>
I 2nd this, Brakes are simple and swap is not to hard. I would also go with the HF no sunroof, lighter car.
Old Jun 4, 2003 | 04:36 PM
that_guy's Avatar
Default Re: new to crx, need help (FURBALL B-16)
do any hf models come with sunroofs? also do they come with power windows and doors? thanks for your guy's responces
Old Jun 4, 2003 | 04:45 PM
tommycrx's Avatar
No to both - if they do, it's some aftermarket McGuyver set-up, which would actually be worse than not having them, because that would most likely lead to problems down the road.
classciv
Jan 4, 2007 03:08 PM
effinnwackk
37
Aug 5, 2004 05:46 PM
3sixtycrew
Dec 4, 2003 06:39 PM
l2ex
Jul 24, 2001 02:56 PM
