Hey Ls/Vtec - Crvtec 'ers, whats your vtec switchover set at?
Old Jun 3, 2003 | 06:03 PM
skribblah's Avatar
Default Hey Ls/Vtec - Crvtec 'ers, whats your vtec switchover set at?
post what cams, and whens the crossover set...
i heard with the torque up you gotta lower the crossover, is this true?
Old Jun 3, 2003 | 07:18 PM
-Racer X-
Guest
Posts: n/a
Default Re: Hey Ls/Vtec - Crvtec 'ers, whats your vtec switchover set at? (skribblah)
yes, lowering the crossover helps, i dont know why, id like to know too...
Old Jun 3, 2003 | 07:36 PM
Triple T's Avatar
Default Re: Hey Ls/Vtec - Crvtec 'ers, whats your vtec switchover set at? (-Racer X-)
I got a chipped mugen p28 and my vtec is at 5500... I have gsr cams.. Hopefully in a while ill be upgrading to either CTR or skunk stage 1.
Old Jun 3, 2003 | 10:32 PM
EVOLMTR's Avatar
Default Re: Hey Ls/Vtec - Crvtec 'ers, whats your vtec switchover set at? (triplet)
On my old b20/vtec setup I had it set at 5500 but once it was dyno tuned it made more power when vtec was moved to 5800.
I had ctr cams dialing in overlap is what makes power on na cars. In most cases vtec at higher rpms.
Old Jun 4, 2003 | 04:41 AM
smokey2.0's Avatar
Default Re: Hey Ls/Vtec - Crvtec 'ers, whats your vtec switchover set at? (EVOLMTR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOLMTR &raquo;</TD></TR><TR><TD CLASS="quote">On my old b20/vtec setup I had it set at 5500 but once it was dyno tuned it made more power when vtec was moved to 5800.
I had ctr cams dialing in overlap is what makes power on na cars. In most cases vtec at higher rpms.</TD></TR></TABLE>
i'm running my vtec at 5200 rpms, that's on stock gsr cams. it seems to pull hardnow, i wanna see what difference ITR cams will make!
Old Jun 4, 2003 | 05:54 AM
Jeff C's Avatar
Default Re: Hey Ls/Vtec - Crvtec 'ers, whats your vtec switchover set at? (smokey2.0)
'01 ITR cams, Vision chipped p28 xover @ 5200. Its only been run on the butt dyno though.
Old Jun 9, 2003 | 08:15 PM
Imadreamer1226's Avatar
ZEX stage 2s vtec x-over at 5800....anything lower seems to want to bog out.
The first lobes seem to make great power too.
Old Jun 9, 2003 | 08:29 PM
VtecDA9's Avatar
My mugen chip is set at 5700 and my skunk chip is at 4900. I run the skunk2 chip and wouldn't go back to the mugen ...
Skunk2 chip 4900
GSR cams
Modified by VtecDA9 at 8:00 AM 8/14/2003
Old Jun 9, 2003 | 10:09 PM
F1Spec's Avatar
5500, hondata, ctr cams.
Old Jun 9, 2003 | 11:37 PM
eg8sleepR's Avatar
Default Re: Hey Ls/Vtec - Crvtec 'ers, whats your vtec switchover set at? (s2geezy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by s2geezy &raquo;</TD></TR><TR><TD CLASS="quote">5500, hondata, ctr cams.</TD></TR></TABLE>
Same setup
Old Jun 10, 2003 | 03:25 AM
evilxkid's Avatar
Default Re: Hey Ls/Vtec - Crvtec 'ers, whats your vtec switchover set at? (eg8sleepR)
5500 skunk 3's, itb's, and reprogramed ecu.
Old Jun 10, 2003 | 07:11 AM
pills_PMD's Avatar
Default Re: Hey Ls/Vtec - Crvtec 'ers, whats your vtec switchover set at? (evilxkid)
my ctr cams stopped making power at like 5100
look at this dyno :
you can see where we had them 5k, 5200 for most runs, then once at 5400
with stock cams i wouldn't put it lower than 5200 and thats' even a little high
my cam timing is +1, 0
Old Jun 10, 2003 | 03:58 PM
LSVTEC96HB's Avatar
Default Re: Hey Ls/Vtec - Crvtec 'ers, whats your vtec switchover set at? (pills_PMD)
I set my V-AFC to 5200, at 5800 vtec hit so hard it would break traction in 1st. with the crossover point lower, the transition is a lot smoother. I am running USDM ITR cams.
Old Jun 10, 2003 | 06:28 PM
skribblah's Avatar
Default Re: Hey Ls/Vtec - Crvtec 'ers, whats your vtec switchover set at? (LSVTEC96HB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC96HB &raquo;</TD></TR><TR><TD CLASS="quote">...at 5800 vtec hit so hard it would break traction in 1st...</TD></TR></TABLE>
NO ****~!!
Old Jun 10, 2003 | 07:28 PM
Allmotornonvtec's Avatar
From: Somewherestreetracing, Md, not a spelling bee
I've dynoed a few cars and the best place is 4600-5000 with no dips in power at all. From stock b16 to built,ls/vtec,b20/vtec,b18c5's
Old Jun 10, 2003 | 08:01 PM
JDM92CX's Avatar
Default Re: Hey Ls/Vtec - Crvtec 'ers, whats your vtec switchover set at? (Allmotornonvtec)
My friend had some Jun 3 cam's in his ls/vtec and had it set at 5800 and that b*tch screeeeeeeeeamed
Old Aug 10, 2003 | 11:47 PM
advanracing62's Avatar
Default Re: Hey Ls/Vtec - Crvtec 'ers, whats your vtec switchover set at? (JDM92CX)
JUN III. 5800. Hondata
Old Aug 11, 2003 | 02:36 AM
allmtr's Avatar
Default Re: Hey Ls/Vtec - Crvtec 'ers, whats your vtec switchover set at? (Jeff C)
5100 with ITRs and a vafc
Old Aug 11, 2003 | 06:03 AM
Hondasaurs's Avatar
B17A1 head, Dinian Chipped P28 vtec x-over at 4800 rev limit set to 7800.
4800 seems to be the sweet spot for my setup.
Old Aug 11, 2003 | 10:07 AM
TheTruth709's Avatar
Default Re: Hey Ls/Vtec - Crvtec 'ers, whats your vtec switchover set at? (Hondasaurs)
right now stock gsr cams stock p72 xover at 4800, waiting on skunk2 stage 3 and hondata to raise it up to 5800 see how it pulls
Old Aug 11, 2003 | 10:17 AM
MAX_CFM's Avatar
Old Aug 11, 2003 | 04:25 PM
y0sh1katu's Avatar
Default Re: (MAX_CFM)
5800 rpm.
skunk2 stage 2.
hondata s200.
207.3whp.
Old Aug 11, 2003 | 05:19 PM
turbociv's Avatar
crower stage 3s with vtec at 6200. any less bogs.
Old Aug 12, 2003 | 04:20 AM
AussieK24's Avatar
Default Re: (turbociv)
5250. Toda A's. Microtech.
Old Aug 12, 2003 | 02:21 PM
97lsvtec's Avatar
5700 skunk stage 2, vafc on skunk chipped p28
