help please no vtec
Old Jun 3, 2003 | 04:10 PM
jaydm98's Avatar
Default help please no vtec
okay guys i need some answers? my vtec is not changing over. so far i checked the ecu, swapped it out with a good ecu stil no vtec. i checked the oil level thats good, the speed sensor works. changed the top part of the solenoid. checked the wiring. no codes. and still no vtec.....
Old Jun 3, 2003 | 04:24 PM
kyle h.'s Avatar
Default Re: help please no vtec (slopokb16crx)
no vtec = good thing.
test the voltage at the sensor wire to see if there is power there.
Old Jun 3, 2003 | 04:38 PM
EL Vap133's Avatar
That is odd, what do you redline at?
Old Jun 4, 2003 | 05:32 PM
jaydm98's Avatar
Default Re: help please no vtec (Vap133)
redline is at 8200........ i dont know whats going on? anyone got any suggestions?
Old Jun 4, 2003 | 06:43 PM
jaydm98's Avatar
anybody?
Old Jun 4, 2003 | 06:58 PM
Mr Furball's Avatar
when you put the wires into the ecu, How were you holding the plug? Allot of times when you hold the plug you can you can go from the wrong side. Make sure you did not put the pins in the wrong place.
When we did my swap, My friend had the plug (wires away from you ) and the directions told him to have the wires face you. Small step but easily overlooked.
Old Jun 4, 2003 | 09:19 PM
Rywire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slopokb16crx &raquo;</TD></TR><TR><TD CLASS="quote">redline is at 8200........ i dont know whats going on? anyone got any suggestions?</TD></TR></TABLE>
Wait, I dont get it, your cutoff is at 82, and you dont have vtec. Sounds like you do to me. I may be missing someting, sorry. Ryan
Old Jun 4, 2003 | 09:36 PM
pokemon's Avatar
yea your car wouldn't rev that high if it didn't recognize vtec. VTEC must be working. Make sure the Oil Pressure Switch is grounded and that the wires are in the right pins
Old Jun 5, 2003 | 02:58 PM
jaydm98's Avatar
Default Re: (pokemon)
oil pressure switch is grounded, and the wires are pinned correctly, and yes the cut off is at 8200 still.
Old Jun 5, 2003 | 09:20 PM
Rywire's Avatar
Default Re: (slopokb16crx)
Sorry but what do you mean by still? Ryan
Old Jun 6, 2003 | 02:45 PM
jaydm98's Avatar
Default Re: (droppedcrxsi)
well i meant the redline is still at 8200, and you cant hear or feel the vtec. i dont know if anyone had this problem before, the engine idles and runs fine, and the car is fairly quick but would be quicker with the vtec changing over.
Old Jun 6, 2003 | 03:07 PM
CRXB16aJDM's Avatar
New User
That's odd. Unless you physically don't have enough oil pressure to turn on vtec. My friends oil pump the screen was so dirty that he was not getting vtec at all. Do you have a cable or electronic speed sensor? When wired my pr3 i believe I had to tap the speed sensor signal back to the ecu side even the gauge cluster was reading it fine, the ecu wasn't getting the signal and ecu has to read atleast 6-10mph before it'll turn it on. But usually you should shoot a code if that was a problem. Weird. Hope it's not a physical problem. Did you get that motor all together? Or is it a rebuild? If it's a rebuild it's very possible they forgot to put in the dowel journals which allow flow for oil, if it's missing the oil may be going everywhere and pressure is messed up. You should test the oil pressure on different ends to see if it's getting enough.
Old Jun 6, 2003 | 04:48 PM
jaydm98's Avatar
Default Re: (CRXB16aJDM)
yeah initially i bought the motor complete,had to get a another block i believe it was off a automatic b16a from a local import shop in town, but i dont think that would matter.and i dont think oil pressure is bad, i took the solenoid off and turned the car on, and oil came flying out fine. so i know that oil pressure is good.
Old Jun 6, 2003 | 04:50 PM
4drEF's Avatar
Keyboard Humorist
Try disconneting the vtec solenoid plug and drive the car. See if it drives EXACTLY the same. Maybe vtec is working and you just aren't feeling it.
If it feels exactly the same (vtec not working) maybe run some wires to the solenoid directly and put it on a switch. Then you can activate it in the car manually and narrow it down to see if your vtec solenoid is shot or if you have a probelem internally with the head.
If it DOES actuate with the rig, then my guess is that you have a wiring problem.
Old Jun 6, 2003 | 04:59 PM
jaydm98's Avatar
Default Re: help please no vtec (4drEF)
ill try doing that disconnecting the solenoid plug and drive the car. i just replaced the top part of the solenoid. and still no vtec. i hope its just a wiring problem not something internally but the engine runs fine, no knocks no nothing, i hope to fix the vtec by next sat so i can run my crx agian. so i hit better times in the 1/8&lt; track here in jacksonville, my best last week was 9.8@73mph&gt;&gt;&gt; i was consistently getting 9.9-10.00 /1/8 passes, they could be better if vtec was working.
Old Jun 8, 2003 | 11:17 AM
jaydm98's Avatar
tried everything still no vtec
Old Jun 8, 2003 | 11:18 AM
jaydm98's Avatar
well the speedometer needle shakes a little, bit could that be the cause?
mugenhatchie
Feb 24, 2007 01:00 PM
Crimson_Tide
Jul 29, 2005 03:18 PM
boosted_teg93
Sep 18, 2004 11:04 AM
96 SI BUBBLE
Jun 3, 2004 08:32 PM
