RSX sway bars
Old Jun 3, 2003 | 03:52 PM
Nothing.Special's Avatar
Default RSX sway bars
What kindve sway bars are you people using? How do you like them? Any kinds you either recommend or prefer over another? Anything will help, Thanks
Old Jun 3, 2003 | 05:27 PM
StreetRacnGsR
Guest
Posts: n/a
Default Re: RSX sway bars (Nothing.Special)
Comptech rear with adjustable rear tiebar. thats what I got and i notice it after i installed it. gotta love comptech. I also got there Front upper Ti strut bar. works great too.
Old Jun 4, 2003 | 12:05 AM
www.HondaWerx.com's Avatar
Default Re: RSX sway bars (StreetRacnGsR)
using the hotchkis comp. package sways. awesome!!! turns at 80mph like a wet dream
Old Jun 4, 2003 | 12:48 AM
sjracer's Avatar
Default Re: RSX sway bars (www.HondaWerx.com)
Progress rear with subframe brace.
Old Jun 4, 2003 | 08:26 PM
Default Re: RSX sway bars (sjracer)
how do you like the progress?
Old Jun 4, 2003 | 08:46 PM
F1HONDA's Avatar
Comptech rear adjustable w/ alum tie bar
Best on the market. Easily adjustable co-axial system. No more messing with end links or making two adjustments. One bolt = easy.
Old Jun 4, 2003 | 08:49 PM
sjracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nothing.Special &raquo;</TD></TR><TR><TD CLASS="quote">how do you like the progress?</TD></TR></TABLE>
The progress is well worth the money. It's a solid 22mm bar. The Hotchkis(sp) bar is hallow so it's a bit lighter. And, it's an adjustable bar. The only thing is it doesn't come with a subframe brace and it tends to snap stock endlinks.
With my progress, i have snapped one stock endlink so far after 1 year of hard use. This was due mainly to my error. Recently i took off the split clamps that keep the sway bar from moving right to left, which caused the endlink to bind and snap the plastic end off of it. I put the clamps back on and haven't had a problem ever since. I love the bar.
When i purchased my progress bar the Hotchkis(sp) bar wasn't out yet. If i were to buy another bar over again i would go with the Hotchkis(sp) because you're able to adjust the "stiffness," but make sure you get their adjustable endlinks also.
Either bar should do a good job with keeping the rear end planted. If you go with a thicker rear bar you might want to look into going with stiffer springs also. Soft springs with a stiff bar in the rear usually results in subframe tear out. I'm using 600lb/in Eibach ERS springs in the back right now.
Good luck...late
Old Jun 5, 2003 | 07:06 AM
B18CXr's Avatar
The CTR/DC5-R rear bar is the best for the $$$.
Old Jun 5, 2003 | 06:39 PM
patrickkkkk's Avatar
Default Re: RSX sway bars (B18CXr)
what would do u use as ure front sway bar?
Old Jun 5, 2003 | 10:25 PM
Mike M's Avatar
Founding Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CXr &raquo;</TD></TR><TR><TD CLASS="quote">The CTR/DC5-R rear bar is the best for the $$$.</TD></TR></TABLE>
Yup
https://honda-tech.com/zerothread?id=526476
Old Jun 6, 2003 | 06:12 AM
fireant's Avatar
Default Re: RSX sway bars (Mike M)
Im using a CTR rear bar (22 mm) and the stock front bar. Im very happy with it, especially the price =&gt; $90
Old Jun 6, 2003 | 09:27 AM
typer100's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike M &raquo;</TD></TR><TR><TD CLASS="quote">
Yup
https://honda-tech.com/zerothread?id=526476</TD></TR></TABLE>
DC5R for me too.
At 86$ you cannot go wrong.
Old Jun 7, 2003 | 05:29 AM
F1HONDA's Avatar
Default Re: RSX sway bars (patrickkkkk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patrickkkkk &raquo;</TD></TR><TR><TD CLASS="quote">what would do u use as ure front sway bar?</TD></TR></TABLE>
use the stock front bar. using a stiffer front bar on a FWD will only induce more understeer. a stiffer bar allows the weight transfer from side to side during cornering to occur more quickly and easily overloads the outside front tire's maximum grip.
BojeEM2
Honda Civic (2001 - 2005)
Feb 18, 2007 11:54 PM
yecora
Jul 9, 2006 02:11 AM
butt 6
Feb 22, 2006 09:43 AM
2000si
Apr 23, 2002 02:07 PM
