Putting 96-00 Ek Civic Rear shocks on Civic or integra Rear Lca's..have any of you done it?
Old Jun 3, 2003 | 03:22 PM
ScaleExtric's Avatar
Default Putting 96-00 Ek Civic Rear shocks on Civic or integra Rear Lca's..have any of you done it?
Well, I got these rear shocks from a friend and of course some of you may know..that the Ek bushing is alot thinner then the integra or civic rear LCA bushing.
Anyhow..what I am questioning is..how did you do this..and if I grind down that bushing..will it effect anything?
Thanks for any info you can provide
Old Jun 3, 2003 | 03:23 PM
JDMCRX's Avatar
Default Re: Putting 96-00 Ek Civic Rear shocks on Civic or integra Rear Lca's..have any of you done it? (Sca
No its ok tokico gives u shimms so just use washers to take up the space i beleive its 2 washers per side
Old Jun 3, 2003 | 03:28 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX &raquo;</TD></TR><TR><TD CLASS="quote">No its ok tokico gives u shimms so just use washers to take up the space i beleive its 2 washers per side </TD></TR></TABLE>no see its the other way around, I have EK struts ..and I am trying to put them on my integra..so my bushing is too wide..will that mess anything up..if I shave it down?
Old Jun 3, 2003 | 03:30 PM
SloCivicHMM's Avatar
not that I know of....just grind it down a lil......np......atleast my 2 cents..
Old Jun 3, 2003 | 03:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowCivicHmm &raquo;</TD></TR><TR><TD CLASS="quote">not that I know of....just grind it down a lil......np......atleast my 2 cents..</TD></TR></TABLE>Im just hoping that bushing isnt hollow..and it needs to shaved down about a 1/2 a inch..has anyone done this before?
Old Jun 3, 2003 | 07:27 PM
bump again...anyone else?
Old Jun 3, 2003 | 08:28 PM
bigTom's Avatar
just shave it down... ull be fine... its a solid piece... just dont shave it down too much
Old Jun 3, 2003 | 08:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9t &raquo;</TD></TR><TR><TD CLASS="quote">just shave it down... ull be fine... its a solid piece... just dont shave it down too much</TD></TR></TABLE>thanks.imma do it this weeken.ill take my chances
Old Jun 3, 2003 | 08:39 PM
piscorpio's Avatar
I had that done on my civic, I used polyurethane replacements for the 92 and just shaved them down before popping them in. No problems, my suspension feels good.
Old Jun 3, 2003 | 10:16 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by piscorpio &raquo;</TD></TR><TR><TD CLASS="quote">I had that done on my civic, I used polyurethane replacements for the 92 and just shaved them down before popping them in. No problems, my suspension feels good.</TD></TR></TABLE>thanks for the answer I have been wanting to hear..
Old Jun 3, 2003 | 11:58 PM
xSpooNxEkx's Avatar
if your using the ek shocks on eg you would have to grind them down... i did it for my friend.... it's sort of ghetto but it doesn't seem like anything bad will happen
Old Jun 4, 2003 | 04:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xSpooNxEkx &raquo;</TD></TR><TR><TD CLASS="quote">if your using the ek shocks on eg you would have to grind them down... i did it for my friend.... it's sort of ghetto but it doesn't seem like anything bad will happen</TD></TR></TABLE>yah, I am going to attempt it..and hopefully nothing wont go wrong
Maui Built
Northern California (Sales)
Dec 30, 2008 04:03 PM
Jonovision
Mar 30, 2008 07:14 PM
