pics of the '89
here are a few pics of my '89 civic I took. The wheels are already sold, so don't worry about that. Just thought I'd see what you guys think. Motor is almost done. Block is finished, still waiting on the head. Fuel set-up is the last step, just waiting on lines and fittings.
http://www.imagestation.com/al...idx=3
for some reason, it starts on the third picture, so you have to click back a few to see them all.
Scale - you the man!. Thanks for the host.
Motor is still in the works-B16A1, Y1 LSD, Spoon PR3,
Block- .25 CTR pistons, shot peened rods, stock crank, stock pulley, CTR flyhweel, balanced and blueprinted. Spoon 2 piece headgasket, Mugen baffled oil pan, stock oil pump, water pump, and timing belt.
Head-Spooky port and polish, 3-angle valve job, bronze valve guides, Skunk2 Stage II cams, gears, springs, high-comp valves, retainers, and intake manifold. RPM Services 68mm throttle body, Vortech fuel rail, RC Eng 270cc injectors, Vortech FPG, JDM ITR header...that's most everything off of the top of my head. I know I'm missing little things, but it's been a long *** day. The block is done. Just waiting on Spooky to finish the port work to start assembling the head. Hopefully I'll have this bitch running this summer. This is a 3 year project (6 months off due to injury in car wreck) for me that is finally coming together. I've put so much into this...just hope it works out the way I'm hoping. Thanks guys.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Goldfingiz »</TD></TR><TR><TD CLASS="quote">Clean as hell. I'd drop it a little bit more
There's no motor in it right now. That's the reason it's looking jacked up front. It's sitting in the showroom of our shop right now until the head is done.
Thanks for all the compliments, guys. I've worked my *** off on this car. I acutally thought about painting the mesh black. I may still do it.
</TD></TR></TABLE>There's no motor in it right now. That's the reason it's looking jacked up front. It's sitting in the showroom of our shop right now until the head is done.
b16nonoy
41
Apr 15, 2007 11:15 PM
getfast
16
Mar 24, 2003 01:03 PM
