95 Accord tech issues...
Old Jun 3, 2003 | 01:44 PM
scuzz18's Avatar
Default 95 Accord tech issues...
My accord has some problems like idles at 1,000-1,500 while im in park (not in gear) and just keeps reving up. Another is my camber are making my tires sit on an angle making my tires wear on the inside. And lastly my car has accel prob wear only in overdrive it seems to lose power.
Old Jun 3, 2003 | 05:41 PM
jfastman's Avatar
Default Re: 95 Accord tech issues... (scuzz18)
Remember to check the basics first (baseline) before you jump to any conclusions. Check ignition timing, fuel pressure, engine vacume, DTC's, and the condition of primary and secondary ignition. High idle can be caused by a vacume leak or a promlem with Idle Air Control system. Also check the condition of the PCV valve-these like to cause driveability problems and they are often over looked. As far as excessive wear on the inside shoulders of your tires is most likely caused by too much negative camber. Have you lowered your car? You need to take your car to an alignment shop for a suspension inspection. They will be able to tell you exactly what you need to do. Trans issues? Can't help you much there. later-fastman
jc1082
Sep 12, 2015 09:52 AM
wrtwdtbbfl05
Feb 17, 2012 03:07 AM
menoride
Dec 11, 2007 06:30 AM
JackAcc
Jan 13, 2003 03:39 PM
AccordVtec
Jan 4, 2003 08:41 PM
