Test pipe dimensions for replacement b series cat
Anyone know the dimension of a b-series cat, specifically the length. I need to have a test pipe made up for a custom exhaust. I will have to replace the test pipe with a cat to pass inspection here (in August). I also do not have one as of yet so that is why I need the dimensions.
Thanks Josh
Thanks Josh
Depends on the header used and the vehicle it is in. If you are having an exhaust made for the car then just get the cat and test pipe made the same length, and the cat back system can be made to fit to either with no problem.
Hmmmmmmm, Do I see a possible test bed for a 2-1/2" cat back exhaust system for a 2nd gen CRX?
yeegsr
Sep 4, 2004 09:35 PM
JDM_Type-R
Jan 2, 2002 04:07 PM
