Weird problem with my car, sometimes radio shuts off, and then turns back on...wtf
Old Jun 3, 2003 | 08:59 AM
krazy's Avatar
Default Weird problem with my car, sometimes radio shuts off, and then turns back on...wtf
i think my car is possessed.. haha
anyway after a hard run, my car radio at times would just shut off, like no power going to it. its weird, im thinking it could be my battery, and maybe i need to pour some distilled water into it. on the other hand, MAYBE its the radio. but i doubt it. I looked at my apexi turbo timer, in the voltage mode, and sometimes the volt drops below 12volts. could this be it? i mean the radio runs off a 12v current right, so as soon as it goes below it will shut itself off?
this only happens after a hard run (8k shifts, etc etc) or when i first start her up while shes been sitting for a while. if, the car is warmed up, and driving, usually its fine. but if i let her sit, and idle it sometimes goes on and off. u guys think the battery isnt charging, or is it a altenator/regulator problem. im not sure where to look besides the battery. thanks guys.
krazy
Old Jun 3, 2003 | 09:02 AM
turbo_ef9's Avatar
Default Re: Weird problem with my car, sometimes radio shuts off, and then turns back on...wtf (krazy)
when that happenend was it like the whole car died and just came back to life? mind did that for sometime and it aws just my ground from the battery.. like everything would shut off and click.. right back on.. it was weird.. i dunno..
Old Jun 3, 2003 | 09:04 AM
krazy's Avatar
Default Re: Weird problem with my car, sometimes radio shuts off, and then turns back on...wtf (eli_vang)
no, the car was fine. just the radio turned off...
krazy
Old Jun 3, 2003 | 09:08 AM
97EXB18C's Avatar
Could be a short in the wiring
Old Jun 3, 2003 | 09:13 AM
krazy's Avatar
Default Re: Weird problem with my car, sometimes radio shuts off, and then turns back on...wtf (97EXB18C)
im wondering that too, but i dunno where it can be. possibly behind the headunit. funny thing is, its been fine all this time. i dont see how a wire can just get loose like that. ill check it out though. thanks for the suggestions, keep em coming.
btw: is it normal for voltage to drop below 12volts when the car is on. i thought it should be around 13-14v when on, and then 12v ish when off.
krazy
Old Jun 3, 2003 | 02:32 PM
krazy's Avatar
BUMP!
krazy
Old Jun 3, 2003 | 03:30 PM
95hbMatt's Avatar
my radio does that **** too! I have a kenwood flip face cd player. When I go to change songs or switch it to the radio it shuts off then back on....I hate it..
Old Jun 3, 2003 | 03:39 PM
krazy's Avatar
Default Re: Weird problem with my car, sometimes radio shuts off, and then turns back on...wtf (95hbMatt)
is it the radio or the car in ur case? i hate electrical ****!
krazy
Old Jun 3, 2003 | 05:22 PM
gezer's Avatar
its just the wires dude, take it to someone who kno's cuase if u dont, dont **** with it. Or ur car just wont be starting, If u take it somewher ask them to look at it then when u find out what it is maybe u can fix it. or just pay the money and sleep easy at night
Old Jun 3, 2003 | 05:28 PM
Damon's Avatar
do you have an alarm? I had this problem once, and it happened after my alarm brain fell from where it was mounted, and the wires where just barely losing connection. whenever I drove over a bump, the radio would cut off.
Old Jun 3, 2003 | 05:39 PM
JDMC5's Avatar
Default Re: (Damon)
Def a short somewhere, or loose connection, or even old wiring. Who knows.
Old Jun 3, 2003 | 05:54 PM
94Solsi's Avatar
bad ground?? or maybe your drawing too much power to another part of your car, ex. powersteering when you turn hard, vtec kicks in at high revs(if you have it). im not sure
Old Jun 4, 2003 | 01:59 AM
krazy's Avatar
Default Re: (Damon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Damon &raquo;</TD></TR><TR><TD CLASS="quote">do you have an alarm? I had this problem once, and it happened after my alarm brain fell from where it was mounted, and the wires where just barely losing connection. whenever I drove over a bump, the radio would cut off. </TD></TR></TABLE>
yea actually this might be it. ill have to check this out. thanks man
as for a short, wouldnt the radio reset itself? this doesnt at all, it just turns off, and then turns on at the same track and place in the song on my CD too. weird ****...
thanks for the ideas guys. i just filled up my battery tonite, so im hoping it was that.
krazy
Old Jun 4, 2003 | 05:31 AM
95hbMatt's Avatar
Default Re: (krazy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazy &raquo;</TD></TR><TR><TD CLASS="quote">
krazy</TD></TR></TABLE>
Mine does the same **** and it doesn't reset itself....it does like you described..cuz if mine was to reset I would have to use this little transmitter to get it to work again...and haven't figured out the prob yet..
Old Jun 4, 2003 | 05:53 AM
BIGthings's Avatar
had the exact same prob with mine. all it was, was the wiring, got it fixed and doesnt happen ne more
Old Jun 4, 2003 | 05:56 AM
_BEN_'s Avatar
Default Re: (95hbMatt)
I had that same problem too but it went away fortunately. I was thinking that it was a grounding problem cuz it usally happens when I would touch it. Once I even felt a spark wich led me to believe my hypothesis was correct. Usally I would get the **** shocked out of me when I would get out of my car from static. When that went away my stereo stopped glitching. No clue though if they had anything to do with each other though.
Old Jun 4, 2003 | 06:01 AM
makaveli284's Avatar
Default Re: (nosepkr)
My problem is kinda similar, yet different. My cdplayer shuts off completely OR starts skipping like crazy ever time i take off hard in first gear, even if i DONT LAUNCH . . it also acts up going from 1st to 2nd when i chirp too hard . . .
Old Jun 4, 2003 | 10:03 AM
Red94Sedan's Avatar
Default Re: (makaveli284)
Dude your CD player isn't connected well. Some ******* wires are lose. Same with
mine and still is sometimes. Didn't feel like taking it to Best Buy, etc. Was ghetto
rigged so thats why also. O yeah check your rear speakers to see if there hooked
up right, because mine are blown and going out, so my cd player would shut donw
and then come on like 2o mintues later. But the problem was rear speakers. So
there u go 2 possible choices. Save some $$ and look at those 1st and if not take
it to Professional place. I hope that really helped. SOrry so long!!
-alex-
Old Jun 4, 2003 | 10:55 AM
krazy's Avatar
Default Re: (Simple 4dR)
well, ive started on my turbo install so i wont be starting the car up till this weekend or so. but i was low on battery juice, thats filled, now im gonna check my wiring. should be fun...
as far as the rear speaker thing, i dunno how this could be possible, but if i dont figure it out, ill have that as a last option to check out. anyway, thanks guys ill let u know if i come up with anything.
btw: i wont be taking my car to best buy or short circuit city, i rather work on my car myself, that way i know wat i did wrong, or where to start. some of those installers are ruthless and ghetto fabolous.
krazy
Old Jun 4, 2003 | 04:53 PM
EggEX2000's Avatar
Default Re: (krazy)
"KRAZY joo so krazy!"
Bump for a good guy
~Mike
Old Jun 5, 2003 | 12:52 AM
krazy's Avatar
Default Re: (EggEX2000)
haha, thanks mike.
oh btw man, my friend found the receipt for the turbo kit. he said hes gonna give u a call about it.
krazy
My_EFsedan
17
Jan 22, 2012 12:43 PM
p3tey2
Honda S2000
Jun 1, 2011 12:40 PM
IMPATIENT
Acura TSX
Dec 7, 2009 04:57 PM
spicoli
Nov 4, 2004 06:59 AM
typerev
Dec 19, 2003 11:47 AM
