Still get a CEL B16a help!
Old Jun 3, 2003 | 07:56 AM
silverCRXTC's Avatar
Default Still get a CEL B16a help!
Ok after my swap i got a CEL for primary o2, i changed out both o2, and check the wiring, nothing i still get a cel under hard driving followed by getting "off it". any ideas, maybe another sensor is bad which casues the car under load change to run rich or lean, tripping the 02? and yes ive reset my ecu many times,
Please help
Old Jun 3, 2003 | 08:45 AM
REDBARON's Avatar
Default Re: Still get a CEL B16a help! (silverCRXTC)
I believe if the FPR is not working properly, it will also cause the ECU to throw a O2 code. I say check that.
Old Jun 3, 2003 | 09:03 AM
EFSiR's Avatar
Do this, reset ECU and go driving. Try reving in 2nd to 5K RPM and decellerate in gear down to 1KRPM. Do you get code 1 or 2?
Let us know.
Old Jun 3, 2003 | 02:50 PM
Default Re: Still get a CEL B16a help! (EFSiR)
i get a code 1, primary o2, and how do i adjust the fuel pressure? and where should it be at?
Old Jun 3, 2003 | 06:50 PM
type Gendy's Avatar
My o2's were wired backwards because i have a pr3 ecu...
MindLess311
Jul 2, 2006 05:36 PM
Oakmanx
Jan 31, 2006 05:12 AM
mhgleitz
Nov 6, 2003 08:43 AM
blackteg
May 15, 2002 11:08 AM
