Need Help On Install The Brake And Bleed The Brakes?
Old Jun 3, 2003 | 12:17 AM
01CWITR's Avatar
Default Need Help On Install The Brake Lines And Bleed The Brakes?
i tried to search but there is not much detail of how to install the SS brake lines and bleed the brake properly.. any instruction of how to change the brake lines and bleed the brakes? Any info will be great!! Thanks!!
Old Jun 3, 2003 | 12:25 AM
zer0zer0 TypeR's Avatar
Default Re: Need Help On Install The Brake Lines And Bleed The Brakes? (01SpecR)
make sure you have a strong set of plyers or a clamp of some sort when removing the line from the fender wall. That bolt is a pain in the ***. Bleeding the brakes, if you do a search you'll find plenty of detailed instructions
Old Jun 3, 2003 | 12:45 AM
01CWITR's Avatar
Default Re: Need Help On Install The Brake Lines And Bleed The Brakes? (zer0zer0 TypeR)
thanks.. also when i replace the new brake pads while i brake it makes some sound from the rotors.. is it normal for the new pads? tried search again for " Bleed The Brakes" can't really find a helpful info
Old Jun 3, 2003 | 03:10 AM
ragejed's Avatar
Mine made a failt scraping noise....they are fine now.
damn axxiss ultimates are dusty tho!
Old Jun 3, 2003 | 02:14 PM
01CWITR's Avatar
Default Re: Need Help On Install The Brake Lines And Bleed The Brakes? (ragejed)
ic.. i guess that's normal for new pads..
Old Jun 3, 2003 | 03:02 PM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zer0zer0 TypeR &raquo;</TD></TR><TR><TD CLASS="quote">make sure you have a strong set of plyers or a clamp of some sort when removing the line from the fender wall. That bolt is a pain in the ***. Bleeding the brakes, if you do a search you'll find plenty of detailed instructions</TD></TR></TABLE>
If you use a flare nut wrench, you greatly reduce the risk of stripping the nut.
Old Jun 3, 2003 | 03:46 PM
Dr Pooface's Avatar
Default Re: Need Help On Install The Brake Lines And Bleed The Brakes? (Reid)
IM me if you need some help, *****.
Old Jun 3, 2003 | 04:03 PM
Flux's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">
If you use a flare nut wrench, you greatly reduce the risk of stripping the nut. </TD></TR></TABLE>
Out of curiosity - how much of a pain in the *** has one created if that nut gets stripped?
Old Jun 3, 2003 | 04:09 PM
Reid's Avatar
Global Moderator
Default Re: Need Help On Install The Brake Lines And Bleed The Brakes? (Flux)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux &raquo;</TD></TR><TR><TD CLASS="quote">
Out of curiosity - how much of a pain in the *** has one created if that nut gets stripped?</TD></TR></TABLE>
If you strip the nut, you would have to use pliers to loosen/tighten it from then on.
Not necessarily all THAT bad, but a PITA for sure.
Old Jun 3, 2003 | 04:42 PM
01CWITR's Avatar
Default Re: Need Help On Install The Brake Lines And Bleed The Brakes? (Dr Pooface)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">IM me if you need some help, *****. </TD></TR></TABLE>
thanks Dylan.
Old Jun 4, 2003 | 09:41 PM
SOUNDEFFECTS's Avatar
VICE GRIPS ownz me today on my brakes!!! It got that nut loose and tight but besides that I used a 10mm to turn it. Works for me.
EngineNoO9
Honda Motorcycles
22
May 25, 2006 04:58 PM
Tutin77
Sep 18, 2004 09:42 AM
HATCHingMN
Feb 24, 2004 09:17 PM
el_Presidente
Feb 12, 2003 09:08 PM
shadowdawn
Aug 6, 2002 02:31 PM
