bonnet vents
Old Jun 2, 2003 | 11:29 PM
jansenrw's Avatar
Default bonnet vents
hmm need to get engine bay temps down... Who sells bonnet vents for a dc2 integra???
Old Jun 2, 2003 | 11:31 PM
TypeR 599's Avatar
Default Re: bonnet vents (jansenrw)
wrong forum but VIS makes some quality chit
Old Jun 3, 2003 | 11:02 AM
syrinx's Avatar
New User
I'm sure someone may know who did this, or may know what the old, archived thread was called, but some one around H-T put a vent on their cf hood. I beleive it was an old vent sourced from an 80's car of some sort. The thread had pics and everything.
As I'm typing this, I think the thread may have been called "how to own a cf hood" or something similar. It may take a long search, but check it out as I'm sure it has all of the info you seek.
Good luck...
Old Jun 3, 2003 | 11:05 AM
Reid's Avatar
Global Moderator
Do you use an oil cooler?
How big is your radiator?
Old Jun 3, 2003 | 11:55 AM
Black Sheep's Avatar
Default Re: bonnet vents (Reid)
Yeah I wanted some vents but my fear of water has stopped me so far.
Old Jun 3, 2003 | 12:09 PM
Big Phat R's Avatar
Get your header ceramic coated.
VERY VERY effective in reducing underhood temps. I did this to my Hytech header and find that I don't even have to pop the hood after gunning the motor at the track for a solid 20 min of W.O.T.
And - it's much cheaper than a new hood - should be a couple hundred Aussie bucks.
Ask at powdercoating places - most of them do ceramic coatings now
Old Jun 3, 2003 | 12:26 PM
Padawan's Avatar
Darth ModerVader
Placing some washers/spacers/etc. between the hood brackets and the hood is an inexpensive and (relatively) visually unobtrusive way to vent the engine compartment. This method takes advantage of the low-pressure area located at the base of the windshield and also has the benefit of reversibility. Lip used a similar setup on his old car, although in his case, I believe the intention was to provide air for the ITB's.
EG6_978
Paint and Body
10
May 22, 2009 02:40 PM
bard329
Mar 1, 2006 06:51 PM
mugenracer
Dec 16, 2004 02:20 PM
miff
Apr 1, 2004 09:06 AM
AllmotorJunkie
Jan 16, 2004 01:35 PM
