Bottomed out ... now lost a small piece of tranny casing
Old Jun 2, 2003 | 07:44 PM
crx00's Avatar
Default Bottomed out ... now lost a small piece of tranny casing
I bottomed out on a dip in the road which caused me to lose a small piece of the tranny casing. I tried to take a pic of it but my digicam batteries are dead (i'll post pics up when they're charged up) . I borrowed a pic from c-speedracing.com to show the damaged area in the pic.
I lost a small piece of metal underneath one of the screws. The threads are exposed but the screw is still tightly intact and it's not leaking oil. Should I worry about this? And Is it ok to put some silicone around the damaged area to protect it?
I'll post an actual pic of the damage after my digicam batteries are charged up. TIA
Old Jun 2, 2003 | 08:07 PM
Ef Whore's Avatar
Default Re: Bottomed out ... now lost a small piece of tranny casing (crx00)
This sounds ghetto but if you want a quick fix, and it's not leaking, smother it in JB Weld and then Permatex. Then proceed to raise your car so you don't bottom out again.
Old Jun 2, 2003 | 08:11 PM
ThatRicerDaniel's Avatar
same thing happen to me but it took out about a golf ball size hole.
Old Jun 2, 2003 | 08:30 PM
crx00's Avatar
Default Re: Bottomed out ... now lost a small piece of tranny casing (Ef *****)
thanks for the tip. Will I have a hard time removing the bolt if i throw on some jb weld and permatex?
Old Jun 2, 2003 | 08:32 PM
keebler65's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ef ***** &raquo;</TD></TR><TR><TD CLASS="quote">This sounds ghetto but if you want a quick fix, and it's not leaking, smother it in JB Weld and then Permatex. Then proceed to raise your car so you don't bottom out again.</TD></TR></TABLE>
that was my first thought as well, however keep in mind if you go this route, you'll never get that bolt out if you ever decide to rebuild the tranny (since he said the thread are exposed). also depending on the damage, it could start leaking oil down the road. so i guess if you never plan on going inside the tranny, then clean it up really well and smother some JB Weld in there and call it a day.
Old Jun 2, 2003 | 08:34 PM
keebler65's Avatar
Default Re: Bottomed out ... now lost a small piece of tranny casing (keebler65)
i just got an idea.....you could put a thin layer of permatex on the exposed threads, let it dry, then smother everything in JB Weld. that way the bolt could still come out. its kind of hard to say if this would be effective though since we dont have pics of the actual damage yet. just thought i'd share that though.
Old Jun 2, 2003 | 08:39 PM
Josh717's Avatar
mines been like that since december hasnt leaked a bit, and i still flog it.
Old Jun 2, 2003 | 10:25 PM
RuthlessEF-9's Avatar
Default Re: (Josh717)
DAMN need to bust out the JB weld until you can get a new trans or until it makes you get a new trans
Old Jun 3, 2003 | 12:03 AM
Just Checking In's Avatar
Default Re: (D16z6turbs)
Put motor oil on the threads, not the damaged casing, and then put the jb weld over it all. It will stick to the casing and not the threads.
Old Jun 3, 2003 | 01:48 AM
iwouldHITit's Avatar
Default Re: (Just Checking In)
lol that happen to me.. but the whole focking bolt is gone. so i just used some hondabond. it leaks a little bit but i add in oil like every other week. was going to weld it but im going to get a new trans soon cause my 4th is gone
Old Jun 3, 2003 | 06:05 AM
rioninja's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Just Checking In &raquo;</TD></TR><TR><TD CLASS="quote">Put motor oil on the threads, not the damaged casing, and then put the jb weld over it all. It will stick to the casing and not the threads.</TD></TR></TABLE>
NO NO NO, it has to be 100% oil free before you JB weld it.
JB weld will actually absorb oil when its still in its liquid state.
Makes it very porous, with the possibility of oil actually seeping
through it later.
Old Jun 3, 2003 | 06:31 AM
Home Skillet's Avatar
Default Re: (rioninja)
JB Waterweld, works for me. Although I'd rather have a new tranny.
Old Jun 3, 2003 | 07:22 AM
Ef Whore's Avatar
Default Re: (Home Skillet)
Hah, keeping it ghetto wit da JB yO! Even if you JB it, trust me you can chizzle it away later if you ever want to swap casings....then spin that bolt out with a air rachet/impact.
Old Jun 3, 2003 | 07:50 AM
silverCRXTC's Avatar
Default Re: (Ef *****)
yeah mine has a whole about a golf ball size also and i got jb welb and it still is leaking, but i found a blown ls tranny for free so i hope to replace the casings
Old Jun 3, 2003 | 04:15 PM
crx00's Avatar
Here's a picture of the damage. Sorry for the bad quality
Can I just throw some hondabond on it .. it's not leaking at the moment ... the oil is coming from a leaky cam seal
Old Jun 3, 2003 | 05:16 PM
viCeVerSa's Avatar
Default Re: (crx00)
hmmm, nasty..... i would use some kind of apoxy type stuff just to seal it up , you may want to get into that tranny one day and jb weld wont permit that......sucks it happened, how dropped is your vehicle?
d16_livin'
Jun 24, 2007 06:17 PM
Dc_John
May 11, 2004 12:01 PM
Malachi
Aug 20, 2003 06:34 AM
Yellow Dragon
May 9, 2001 12:15 PM
