ARP rod bolt question
Old Jul 16, 2001 | 08:55 PM
13secLSVTEC's Avatar
New User
Default ARP rod bolt question
Will B16 ARP rod bolts work on LS rods?
The reason I ask is because B16 bolts are 8mm, and B18 are 9mm
Yes, No, Maybe?
Old Jul 16, 2001 | 09:37 PM
accordking's Avatar
Default Re: ARP rod bolt question (13secLSVTEC)
The B series bolts are all 11mm and D series are 10mm and Prelude/Accord are 12mm. If you are going to use ARP's make sure you use the Bseries and for LS/VTEC you have to GSR bolts or studs.
Old Jul 17, 2001 | 01:12 AM
New User
Default Re: ARP rod bolt question (accordking)
Two avaible ARP rod bolt sets for Honda B series:
ARP-208-6001 Honda 1.2L-1.6L 8mm
ARP-208-6401 Acura 1.8L 9mm
My question is will the 8mm holp up on LS rods...
Old Jul 17, 2001 | 07:20 AM
HX_Guy's Avatar
From what I have heard...the 9mm Honda one is too big and youre actually supposed to use the 8mm ones even though it says 1.2L-1.6L
Old Jul 17, 2001 | 12:15 PM
accordking's Avatar
whoe! I messed up!! I thought you were talking about the head bolts?!
Old Jul 17, 2001 | 01:50 PM
hybrid_KJ's Avatar
For b18a rods the 8mm ones are what you need. That's what I used. On the b18b's I've heard you use the 9mm ones but I'm not sure on that since I've never built a b18b bottom end. Can someone confirm or deny this?
Old Jul 17, 2001 | 03:24 PM
non-VTEC's Avatar
you will need the 8mm ARP rod bolts for the B18B rods.........i'm using them in my car right now..........
Old Jul 17, 2001 | 04:51 PM
New User
Default Re: ARP rod bolt question (non-VTEC)
Thanx for the input all....
C_Rock77
10
Mar 24, 2010 10:15 AM
skoodles2k6
Jun 20, 2007 02:46 PM
ftp2004
Dec 29, 2004 07:50 AM
boosted k20
Nov 20, 2004 09:23 AM
NC-B17A
Jul 12, 2002 12:55 PM
