Spring/Strut install: Torquing bolts to a certain level?
Old Jun 2, 2003 | 11:56 AM
rubens's Avatar
Default Spring/Strut install: Torquing bolts to a certain level?
For this setup (detailed at http://www.team-integra.net/se...D=494)
Should I use a torque wrench to make sure they're torqued to a certain spec?
Rubens
Old Jun 2, 2003 | 11:23 PM
rubens's Avatar
Default Re: Spring/Strut install: Torquing bolts to a certain level? (rubens)
Old Jun 3, 2003 | 02:13 AM
slomob18b's Avatar
Yes, use a torque wrench to make sure all the bolts are torqued to spec. Suspension is a very important part of your car and you do not want any bolts to come undone.
EDIT: Just play it safe and use a torque wrench
Old Jun 3, 2003 | 03:31 AM
beefpigs's Avatar
Default Re: Spring/Strut install: Torquing bolts to a certain level? (slomob18b)
I did mine about 2 months ago and I didn't torque them to any specs but I had an air gun and ratchet. They ain't coming loose.
Old Jun 3, 2003 | 01:18 PM
rubens's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomob18b &raquo;</TD></TR><TR><TD CLASS="quote">Yes, use a torque wrench to make sure all the bolts are torqued to spec. Suspension is a very important part of your car and you do not want any bolts to come undone.
EDIT: Just play it safe and use a torque wrench </TD></TR></TABLE>
Would I need a helms to find what the specs are
Old Jun 3, 2003 | 01:54 PM
Tweakmeister's Avatar
a Helms and a Torque Wrench go hand in hand when working on your car.
Get them both and do it right the first time.
Old Jun 4, 2003 | 01:01 PM
MachAF's Avatar
I can't remember off the top of my head. but its either 35 or 45 ft lbs. All the bolts are the same. Pretty much. I think one may be different.
Old Jun 7, 2003 | 05:53 PM
rubens's Avatar
Default Re: Spring/Strut install: Torquing bolts to a certain level? (MachAF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MachAF &raquo;</TD></TR><TR><TD CLASS="quote">I can't remember off the top of my head. but its either 35 or 45 ft lbs. All the bolts are the same. Pretty much. I think one may be different. </TD></TR></TABLE>
any chance someone could find out for me so i dont have to buy a helms?
Old Jun 7, 2003 | 06:06 PM
IN VTEC's Avatar
Off the top of my head...
strut top nuts (14mm deep, better with 1.5"+ extension) = 36 lb*ft
front upper shock fork bolts (14mm) = 32 lb*ft
front lower shock fork bols (17mm) = 47 lb*ft
rear lower control arm bolts (14mm) = 40 lb*ft
rear swaybar bolts (14mm) = 29 lb*ft
Real mechanics don't need torque wrenches.
Old Jun 9, 2003 | 12:38 PM
rubens's Avatar
Default Re: Spring/Strut install: Torquing bolts to a certain level? (IN VTEC)
lol, thanks.
Old Jun 9, 2003 | 12:40 PM
Seedc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">Off the top of my head...
Real mechanics don't need torque wrenches.</TD></TR></TABLE>
lol.. i need these thanks
Chrisfball12
Jan 15, 2008 04:28 PM
JDMCRX
Jul 5, 2004 01:10 PM
Marcos
Mar 11, 2004 02:57 PM
May 27, 2002 06:09 AM
