radiator options.. and what del sol rad is this?
Old Jun 2, 2003 | 08:37 AM
elmalouno's Avatar
Default radiator options.. and what del sol rad is this?
trying to figure out what radiator to use now...
91 crx is getting a 96 gsr motor... the motor i bought came with this del sol radiator:
but i don't think that puppy is going to bolt up. i heard that the 90-93 teg radiators bolt up? is there an advantage to getting the teg one over a crx rad? thanks
also are there after markets worth noting?
Old Jun 2, 2003 | 10:37 AM
slowpokesi's Avatar
Default Re: radiator options.. and what del sol rad is this? (elmalouno)
the above radiator is a standard del sol or 92-00 civic radiator, it will not bolt in unless you get a jimfab crossmember or z10 bars, or place racing crossmember,
however the crx radiator that you have now should be find for a gsr motor.
Old Jun 2, 2003 | 12:14 PM
elmalouno's Avatar
Default Re: radiator options.. and what del sol rad is this? (slowpokesi)
i was planning on gettin a jimfab down the road alittle... will my rad work with it also? or should i hang onto this thing?
Old Jun 2, 2003 | 04:34 PM
CrxSi10's Avatar
Yes, you stock radiator will work. You can hang on to it if you are going turbo otherwise, you don't really need to. What is the price on that radiator?
Old Jun 2, 2003 | 05:24 PM
elmalouno's Avatar
Default Re: radiator options.. and what del sol rad is this? (CrxSi10)
its on ebay going cheap so far... no bids.. and no reserve... i can link u if your interested...
louevilhatch
Nov 7, 2007 04:29 AM
jdmCivic925
Jul 13, 2004 04:27 PM
djentranced
Jun 5, 2003 06:26 PM
