Which ecu is better to run on a h22? p28?p72?p13?
Old Jun 2, 2003 | 08:22 AM
eg:R's Avatar
Default Which ecu is better to run on a h22? p28?p72?p13?
have anyone try or used a custom or custom h22 spec chip on a p28 or p72? i have used a chip p28 mugen(b spec's) and a chip p13 spoon, comparing both on the dyno, the p13 give more tq. the hp curve seem to be the same, any exp. would be thankful,
Old Jun 2, 2003 | 10:08 AM
aklucsarits's Avatar
New User
Default Re: Which ecu is better to run on a h22? p28?p72?p13? (jacklee)
Did you do air:fuel plots for both when you had them on the dyno? The A:F ratio for each would be a critical factor in your choice.
Andrew
Modified by aklucsarits at 3:18 PM 6/2/2003
Old Jun 5, 2003 | 10:18 AM
eg:R's Avatar
i did not do that
O RLY
Oct 5, 2004 10:42 PM
prjctCIVIC
Jun 9, 2002 02:57 PM
