Idle problem .... 4th gen
Old Jun 2, 2003 | 08:14 AM
RUBZERK's Avatar
Default Idle problem .... 4th gen
Just recently my car has been acting weird.
It idles at 400rpm's, & tends to shut off. How do i go about adjusting it to idle around 800rpm's.
Old Jun 2, 2003 | 03:19 PM
Charlie Moua's Avatar
Default Re: Idle problem .... 4th gen (RUBZERK)
HUM... check all your vacume line first befor adjsuting your idle screw.
Old Jun 2, 2003 | 10:12 PM
RUBZERK's Avatar
Default Re: Idle problem .... 4th gen (Charlie Moua)
All vac lines are ok
Old Jun 2, 2003 | 10:35 PM
spankey167's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RUBZERK &raquo;</TD></TR><TR><TD CLASS="quote">All vac lines are ok</TD></TR></TABLE>
adjust your idle with a flat head screwdriver... its located near the throttle body...
Old Jun 3, 2003 | 06:45 AM
RUBZERK's Avatar
Default Re: Idle problem .... 4th gen ([167]spankey)
There is no flat head screw to adjust?
What do I do?
Old Jun 3, 2003 | 05:58 PM
jfastman's Avatar
DO NOT ADJUST IDLE BY TURNING THE BIG SCREW! That leads to other problems, like erratic idle and fuel cut. Open up the throttle plate and make sure it is clean first. Use a solvent spray suitable for cleaning throttle bodies (make sure it won't melt plastic) and an old toothbrush. Scrub that sucker clean. Next, check ignition timing. If that's ok, check the throttle postion sensor voltage at idle. It should be around 4.6 volts. Also check for any vacume leaks. Use a vacume gauge. A healthy engine at sealevel should pull about 20-21" of mercury. Subtract an inch for every thousand feet above sea level. That should get you pointed in the right direction. Dont forget to check 'The Idle air control system, laters-fastman
Old Jun 3, 2003 | 10:21 PM
RUBZERK's Avatar
Default Re: Idle problem .... 4th gen (jfastman)
YOU LOST ME DUDE!!!
What would it cost mt to go to a shop to have this done?
Old Jun 4, 2003 | 09:43 AM
jfastman's Avatar
For a driveability diagnosis at reputable shop should cost between 65-80 bucks. that would be you best bet to get your problems resolved.
Old Jun 8, 2003 | 06:22 PM
preluder's Avatar
yeah im gonna take mine to honda to run a diagnosis,i dont have a voltmeter and my car is throwing no codes and im not sure if its the ecu or if i got vacuum leaks. I just want to know how many problems i have on that car. im about to find out.
Old Jun 8, 2003 | 06:29 PM
RUBZERK's Avatar
Default Re: Idle problem .... 4th gen (preluder)
Well i fixed my problem.
i replaced my valve cover ring gaskets & spark plugs.
seems my plug tubes were full of oil. i used a turkey baster to suck all the oil out before changing them, now its fine.
TegraD
May 15, 2009 02:55 PM
Toanz
Jun 23, 2008 03:57 PM
jdmCivic925
Oct 25, 2005 02:37 PM
eg6nes
Feb 21, 2005 03:57 PM
Norcalstoppy
Jul 30, 2002 06:01 AM
