JDM h22 compression psi?
Old Jun 2, 2003 | 08:04 AM
jdmcivicferio's Avatar
Default JDM h22 compression psi?
What should the compression in psi be on a jdm h22, is 210 across any good? thanks.
Old Jun 2, 2003 | 10:42 AM
homesauce's Avatar
Default Re: JDM h22 compression psi? (jdmcivicferio)
That compression ratio sounds about right, anyone want to verify? Secondly, compression ratio is not in units of PSI, compression ratio does NOT have any units of measurement.
Old Jun 2, 2003 | 11:50 AM
bolt on lude's Avatar
Its not really the number that is important when doing a compression check. Its how close each cylinders compression is to one another. The actual value will vary by how many times you crank the engine while doing the check. Thats a good number if the rest are the same or very close to that.
Old Jun 2, 2003 | 01:14 PM
PrecisionH23a's Avatar
Default Re: (bolt on lude)
i would love to explain this to you, but i dont have the time right now. So read this:
http://www.hotrodders.com/cgibin/ubb/15/005666
6E LUDE
Nov 10, 2005 05:38 AM
huge230
Oct 2, 2005 10:40 AM
vtec95
Jan 12, 2005 04:03 PM
