does anyone know the codes?
Old Jun 2, 2003 | 01:09 AM
4gnhatch's Avatar
Default does anyone know the codes?
can anyone help me with the codes? my car is thrwing a 1 and the rpm gauge goes crazy and the engine light turns on. thanks in advance.
Old Jun 2, 2003 | 03:03 AM
bryant's Avatar
Default Re: does anyone know the codes? (4gnhatch)
What motor, what ECU?
Sounds like your Igniter in your Dizzy is broken...
Old Jun 2, 2003 | 06:24 AM
ThatRicerDaniel's Avatar
a 1 is your 02. but the needle indicates a dizzy problem.
Old Jun 2, 2003 | 07:59 AM
matt j's Avatar
Default Re: does anyone know the codes? (NitrousDreamz)
Code 0 _____ Faulty ECU
Code 1 _____ Oxygen content
Code 2 _____ Does not appear to exist
Code 3 _____ MAP sensor
Code 4 _____ Crank angle sensor
Code 5 _____ MAP sensor again
Code 6 _____ Coolant temperature
Code 7 _____ Throttle angle
Code 8 _____ Top dead center sensor
Code 9 _____ No. 1 cylinder position (only on 1.6L)
Code 10 ____ Intake air temperature
Code 11 ____ Does not appear to exist
Code 12 ____ Exhaust gas recirculation system
Code 13 ____ Atmosphric Pressure
Code 14 ____ Electronic air control (EACV)
Code 15 ____ Ignition output signal
Code 16 ____ Fuel injector
Code 17 ____ Vehicle speed sensor
Code 18 ____ Does not appear to exist
Code 19 ____ Lock up control solenoid (auto trans only)
Code 20 ____ Electric load
Old Jun 2, 2003 | 09:24 AM
4gnhatch's Avatar
thanx for the codes man you kick ***!!
Old Jun 2, 2003 | 09:29 AM
4gnhatch's Avatar
also is the 02 is what keeps the engine light on?
Old Jun 2, 2003 | 11:14 AM
Default Re: (4gnhatch)
any code will keep the ingine light on. are you 100% you have a code 1?
Old Jun 2, 2003 | 12:35 PM
Aphrodavid's Avatar
Default Re: does anyone know the codes? (mattED6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattED6 &raquo;</TD></TR><TR><TD CLASS="quote">
Code 2 _____ SECONDARY O2 SENSOR(IF APPLICABLE)
wickedEFguy's Avatar
http://www.c-speedracing.com/faq/05.php
there you go
drewboy
May 14, 2005 10:03 PM
h22acivichybrid
Jun 3, 2004 03:24 PM
Me2
Apr 11, 2004 03:13 PM
foesicks
Jun 4, 2003 09:47 AM
drunk
Oct 20, 2002 03:29 PM
