b20z oil pump question
Old Jun 1, 2003 | 09:26 PM
b20ek's Avatar
Default b20z oil pump question
On the old honda hybrid site they said the b20z used the same oil pump as a gsr. Is this true? If it is then shouldn't you be able to use a gsr timing belt?
Old Jun 2, 2003 | 03:08 PM
Skip01's Avatar
yes this is true,just make sure if you use a vtec oil pump use a vtec timing belt and vice versa.I don't think the b16 will work.
Old Jun 2, 2003 | 05:13 PM
built562's Avatar
Default Re: (Skip01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skip01 &raquo;</TD></TR><TR><TD CLASS="quote">yes this is true,just make sure if you use a vtec oil pump use a vtec timing belt and vice versa.I don't think the b16 will work.</TD></TR></TABLE>
the oil pump does not affect whcih timing belt you use, i think you mean water pump.
but the b20 oil is the same as gsr, and if you use a vtec water pump use a vtec timing belt, and if you use a non-vtec water pump use a non vtec timing belt.
Old Jun 3, 2003 | 08:07 AM
Skip01's Avatar
Default Re: (akumaracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by akumaracer &raquo;</TD></TR><TR><TD CLASS="quote">
but the b20 oil is the same as gsr, and if you use a vtec water pump use a vtec timing belt, and if you use a non-vtec water pump use a non vtec timing belt.</TD></TR></TABLE>
true,true.My fault at least i had some of it right.peace.
beaneg6
Mar 10, 2009 04:08 AM
racingant
Dec 22, 2005 08:11 AM
Hondasaurs
Feb 25, 2003 04:20 PM
3rdGteg
Nov 3, 2002 11:08 AM
