Computer? Distributor Cap? Starter?
Where is the computer in a '88 CRX DX? Does the computer have a light that blinks and the number it blinks tells you the problem, like I've seen them on other cars. The car doesn't start after it was started once. You have to try to turn it multiple times, then if you're lucky it will start. Could that be the distributor cap, starter, or something else? It has new plugs and wires and a valve cover gasket kit. Thanks.
Its on the floor under the carpet, where the passengers feet would be. You will see a window which will let you see the blinks.
Oh also you problem is the main relay...
http://www.fourthgenhatch/mainrelay.html
Its not my computer, the light doesn't blinks only once when you turn the key in the "on" position. Thats fine.
The mian relay. What is it? Where is it? And how much does it cost to fix it.
Could it also be either the distributor cap, distributor, starter, or coil (or does the CRX have a coil-less ignition)?
mastapw7
Jan 21, 2012 11:31 AM
jdmkidUK
Nov 30, 2011 05:49 PM
