What CAT are you using with your MUGEN Header?
Old Jul 16, 2001 | 01:06 PM
nsx-Animal's Avatar
Default What CAT are you using with your MUGEN Header?
I just installed a Mugen header on my ITR and I could not use the CARSOUND cat with it. Had to go back with stock cat. What cat do I have to get with this setup?
Old Jul 16, 2001 | 01:16 PM
Big Phat R's Avatar
Default Re: What CAT are you using with your MUGEN Header? (ITR-Animal)
Is that a USDM or JDM header?? (i.e. 2.25 vs 2.5" collector?)
Old Jul 16, 2001 | 01:25 PM
Austin's Avatar
Ummmm....if the stock cat fit on your Mugen header, it looks like you were sent the US market header with the smaller collector, I'd be if I were you.
Old Jul 16, 2001 | 01:50 PM
Big Phat R's Avatar
Default Re: What CAT are you using with your MUGEN Header? (00itr0757)
King Motorsports will send you the USDM modified header unless you specify otherwise. Thus it should bolt up to a stock catalytic.
If the Carsound cat is a 2.5" - you should have told whomever you ordered the header from that you intended to use a non-stock/high flow cat. It's not their fault!
Old Jul 16, 2001 | 01:55 PM
nsx-Animal's Avatar
I guess it is my FU@%$ UP.
Old Aug 1, 2001 | 03:26 PM
arren123's Avatar
Any noticible difference once you put the header on even though it was the USDM one?
Old Aug 1, 2001 | 03:55 PM
Comtechgsr2000s's Avatar
New User
Well since your stuck with it, try a Random Tech cat. It will work with your headers.
Old Aug 1, 2001 | 05:04 PM
Black SVT's Avatar
Default Re: What CAT are you using with your MUGEN Header? (Mugenblkgsr2000)
Cat Testpipe
Old Aug 1, 2001 | 05:17 PM
pho king guy's Avatar
Default Re: What CAT are you using with your MUGEN Header? (Dc2k-specR)
i agree... i'm about to put test pipe in mine, that and headers... already have intake/exhaust
going for subtle... till i get my t-59 turbo *heh* *heh* *heh*
[Modified by gan ni nia, 8:19 PM 8/1/2001]
Old Aug 1, 2001 | 05:45 PM
jetydosa's Avatar
25 Year Member
Default Re: What CAT are you using with your MUGEN Header? (gan ni nia)
I recently got the USDM Mugen header and was pleasantly surprised with the power gains. Def seems to have more power above 6500 or so, and of course the weight savings. I didnt want to replace the factory cat, and I dont plan on ever having more than I/H/E, so the USDM was the way to go for me. (Plus I got the header used at good price!)
Old Aug 2, 2001 | 06:03 AM
MPH's Avatar
MPH
New User
Testpipes rule!
[Modified by MPH, 10:04 AM 8/2/2001]
civic2slo
Dec 7, 2006 06:13 AM
schumi
Jul 23, 2005 09:14 AM
mkiv98
Jan 21, 2005 01:51 PM
00EM1Si
Nov 14, 2003 07:58 PM
u0f
Nov 5, 2003 05:46 PM
