Rough Idling when sitting still and AC on..................
Old Jul 16, 2001 | 12:54 PM
bmellis's Avatar
New User
Default Rough Idling when sitting still and AC on..................
I was wondering if someone knew why 97 honda prelude would be idling low and rough when AC is on, could it be the AC compressor, or is it just a minor adjustment with the idle, If someone had simular problems to this could you please reply to this topic.
Thanks.
Old Jul 16, 2001 | 01:01 PM
CardDealer's Avatar
Banned
Default Re: Rough Idling when sitting still and AC on.................. (bmellis)
Modified by CardDealer at 4:14 AM 11/16/2006
Old Jul 16, 2001 | 01:29 PM
fixhondas's Avatar
Usually- the A/C kicked on will make the idle rough- Did you just have your battery replaced or disconnected? Tight valve clearances and worn or too hot spark plugs will cause a rough idle as well. If it is not too irritating- I wouldn't worry about it. I'm assuming you have an automatic?
iboughtas2k
13
Jun 18, 2011 04:04 PM
Rooftop-Special
Sep 2, 2010 08:08 PM
blackludebosh
Aug 9, 2008 01:33 AM
Apocolipse269
Sep 2, 2004 02:31 PM
riceball777
Aug 18, 2003 10:11 AM
