How to bleed the clutch.....HELP NEEDED FAST
take off the clutch resevoir cap
make sure it is full
pump the pedal 3-4 times
have someone SLOWLY push in the pedal while you SLOWLY let open the bleeder and allow air/fluid to escape and close the valve before they reach the floor with the clutch
REPEAT until clutch pedal is good
Have someone push the pedal to the floor and hold it, open the bleed valve, close the bleed valve, Repeat. follow the cycle 2 times and refil the resivoir and start again.
dc2LS
Oct 16, 2010 04:56 PM
