grinding ??????
i know my clutch is bad but it might be worse that i thought..
when i go into 1st....strat to move.....clutch is fully engaged and i got this very quick grinding noise.......like i grinded a gear......but its while moving .......no boggs or hesataton when it happened but it did it 3 time yesterday and that was it ......??? im lost on this one
could it be the relase bearing siezing up
__________________
__________________
Have you tried changing the transmission fluid?, mine was grinding until I changed my fluid several times to flush the tranny fluid. 3 times, but you'll know exactly after you change the clutch. I forgot what it was called but, on top of your tranny you have a shift lever that shifts you into gear. That could possibly be leaking from hard shifting, intern leaks tranny fluid. Thats what I experienced hope it helped.
DC5Danny
Jan 21, 2008 08:36 AM
