Tire pressure for a crx with 16s
i work for a tire company (discount tire) and that isn't what the side of the tire says. the only rating they give you on the tire is for MAX tire pressure which is something that most of hondas guys should NEVER run. i'd suggest the you run them at 32 psi. make sure to set the pressure when the tires are cold (morning). i was running the same pressure on my 17's and it felt pretty damn good.
adrian1281
Jun 28, 2003 08:39 AM
