JDM H22a
Old Jun 1, 2003 | 08:50 AM
explosive's Avatar
Default JDM H22a
What octane does a JDM H22a require? I am hoping it is 93 or below, cuz I would really like to put this engine in my Del Sol.
Old Jun 1, 2003 | 10:31 AM
Cottonwoodz's Avatar
Default Re: JDM H22a (explosive)
I run 93 in mine, got the base timeing set at 18-19 degrees. No pinging whatsoever.
Old Jun 1, 2003 | 12:39 PM
Kidd_Stylez's Avatar
I would imagine more like 91 and up. Not 93 and below because that would include 87 octane and i dont think that would be good.
Old Jun 1, 2003 | 12:41 PM
Elkins911's Avatar
Default Re: JDM H22a (Kidd_Stylez)
all jdms are built for higher octane because of the higher compression. octane booster works fine too. 91-93 + octane booster =
Old Jun 1, 2003 | 01:09 PM
4bidden's Avatar
Default Re: JDM H22a (Elkins911)
My H22 ran fine on 91.
Old Jun 1, 2003 | 04:08 PM
Mikey3000's Avatar
91+ would work fine. its not that high compression (10.6:1)
Old Jun 1, 2003 | 04:57 PM
Jago's Avatar
Default Re: JDM H22a (Salvatore Leone)
Yes It Is!!!!!!!
Old Jun 1, 2003 | 07:42 PM
explosive's Avatar
Yeah I was thinking that 91 should be sufficient simply because the ITR, Celica GT-S, etc. have much higher compression ratios and can run on 93.
Old Jun 2, 2003 | 12:27 AM
PreludeRacer023's Avatar
Default Re: (explosive)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by explosive &raquo;</TD></TR><TR><TD CLASS="quote">Yeah I was thinking that 91 should be sufficient simply because the ITR, Celica GT-S, etc. have much higher compression ratios and can run on 93.</TD></TR></TABLE>
umt he ITRs compression isnt that much higher its only 11.0 to 1 which is like .4 tenths...and high compression is like anything over 12 to 1, thats where feul octane becomes a critical factor, in a stock motor any good gas 91- and up will work fine...ive run 93 everytime in mine..peace
Old Jun 2, 2003 | 03:50 AM
KGAccord's Avatar
Default Re: (PreludeRacer023)
i run 93 and it's fine, but i do suggest sticking to name brand gas like mobil,sunoco, etc.
Old Jun 2, 2003 | 07:08 AM
rjr162's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PreludeRacer023 &raquo;</TD></TR><TR><TD CLASS="quote">
umt he ITRs compression isnt that much higher its only 11.0 to 1 which is like .4 tenths...and high compression is like anything over 12 to 1, thats where feul octane becomes a critical factor, in a stock motor any good gas 91- and up will work fine...ive run 93 everytime in mine..peace</TD></TR></TABLE>
Until you hit the GDI engines (Gas Direct Injection). Those things run a 40:1 at points. Very sick. Also get more HP than Port Fuel Injection. Oh and you can run something like a 12.5:1 on pump w/o a problem.. with gas with less sulfer (so the US is out on the 12.5:1 compression but can still pull the 40:1 A/F)
Old Jun 3, 2003 | 08:01 AM
vtecjb's Avatar
def. 93, 91 would work but personally i would much rather use 93
Old Jun 8, 2003 | 03:27 AM
visual's Avatar
Default Re: (99redlude)
i would hope that 91 would do, cuz in socal that's the highest we have, damn bastage emissions.
TypeOneSiR
Oct 29, 2007 03:47 PM
racetowin
Jul 15, 2006 09:29 AM
mugenmseven
Jun 29, 2005 12:56 PM
Monkey Fing a Coconut
Mar 8, 2004 04:48 AM
deevergote
May 12, 2003 06:05 AM
