ingalls camber kit, searched
Old Jun 1, 2003 | 08:27 AM
Rywire's Avatar
Default ingalls camber kit, searched
Hi, I am sorry to start another post like this. I was reading the archived posts, and some people had to cut their UCA to fit the ingalls extreme kit on their car. How low are your cars that had to do this? I have sportline springs(1.8 drop), do you think I will have to do this? Or will they go in properley? Also, do you think I could get away with the -3/4° to 1°, or should I get the +1.25° to 3°?
Old Jun 1, 2003 | 10:43 AM
Rywire's Avatar
Default Re: ingalls camber kit, searched (droppedcrxsi)
OK, I did a little more searching, and I think I should go with the extreme kit. Do you guys think I will be ok with clearence issues with sportline springs? Thanks
Old Jun 1, 2003 | 08:45 PM
Rywire's Avatar
Old Jun 2, 2003 | 12:43 PM
Rywire's Avatar
Someone has got to have sportlines with a ingalls. Ryan
Old Jun 2, 2003 | 01:06 PM
slowpokesi's Avatar
i have h&r 2 inchers with ingalls extreme kit,
i installed it and i noticed slight rub, looked again and i hadnt installed the camber kit properly, there were these brass rings like in the chape of a c that you have to take off, so i took those off and no more problems.
Old Jun 2, 2003 | 03:10 PM
Rywire's Avatar
Default Re: ingalls camber kit, searched (slowpokesi)
Cool, Thanks
Old Jun 2, 2003 | 05:41 PM
USDM 4G VTEC's Avatar
i have ebay coilovers with 89 accord front struts....lowered til wheelgap its gone.... wich is about 2.0-2.50 inches....
yes i had to cut some of my inner fender.... but no more tire wear.. i rather cut the fenders a lil than killing my tires.....
also u might wanna look into ball joint camber kits if u dont wanna cut ur inner fenders
http://www.iapdirect.com has them
Old Jun 2, 2003 | 09:44 PM
Rywire's Avatar
Default Re: ingalls camber kit, searched (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">i have ebay coilovers with 89 accord front struts....lowered til wheelgap its gone.... wich is about 2.0-2.50 inches....
http://www.iapdirect.com has them</TD></TR></TABLE>
Ball joint kits are cool, but I have a 89, and my upper ball joint is welded to the UCA. I think my only option is the ingalls style. Unless I swicth to 90-91 UCA's.
Does anyone run sportlines, and ingalls? Thanks
Old Jun 3, 2003 | 06:56 AM
StlSupra's Avatar
i've only heard about people talking about ingalls or the spc ball joints. does anyone make a full uca replacement thats adjustable?
Old Jun 3, 2003 | 07:33 AM
Ef Whore's Avatar
Default Re: ingalls camber kit, searched (StlSupra)
All years UCA are welded....he means the adj. lower ball joint. The uppers can be removed from the arm but it is a bitch and not worth it IMO.
Old Jun 3, 2003 | 07:37 AM
StlSupra's Avatar
Default Re: ingalls camber kit, searched (Ef *****)
thanks, in a road racing application is there a durability issure between the two?
Old Jun 3, 2003 | 07:47 AM
Rywire's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StlSupra &raquo;</TD></TR><TR><TD CLASS="quote">i've only heard about people talking about ingalls or the spc ball joints. does anyone make a full uca replacement thats adjustable?</TD></TR></TABLE>
This would be very nice, like a skunk 2 aplication, exc... However, I dont think they are made for our model. Ryan
Anyone running a ingalls with a 1.8 drop spring (sportline).
I guess it will work, because the person above had a 2" drop without problems, but I would like to make sure. Thanks, Ryan
Old Apr 26, 2005 | 04:36 AM
jadugartir's Avatar
I lost my printout from the alignment place showing how bad each of my wheels were... so now i have no clue which kit to buy.
swollen_cu
Feb 26, 2008 01:24 PM
JTaudio0212
Honda Civic (2006 - 2015)
18
Oct 25, 2007 04:58 PM
hondamanforlife
14
Apr 4, 2007 07:33 PM
IloveNewt
May 5, 2003 10:24 AM
