A/c With bseries swap in EF Problems
Old Jun 1, 2003 | 08:01 AM
STK B16's Avatar
Default A/c With bseries swap in EF Problems
Guys. i tried putting a/c back into my car this weekend. ran into soem problems.. first of all. i got all the lines (piping) in the engine bay from a 88-89 dx. heres my setup on my car b16a3 with HCP motor mounts. and im using the 94 Delsol A/c Bracket.
First when i tried going to put the bracket in. the Crossmember was in the way by like 1/2 an inch. on the bottom of the bracket.. so i unbolt my crossmember and let it down to put the bracket on . Now i put the 94 delsol A/c Compresser in. it even take more space. Now that the a/c compresser is on the bracket.. I go try to put my crossmember back up . I find out that the compressor is now in the way . i cant put the crossmember back on. the compressor is now sittin lower than the bracket inself.
The other problem i have is that the piping does not run correctly onto the compressor. It seems like i have to bend it alot to get it right. even tho i got one on.. the piping was 1 inch too short..
If anyone who got through this problem.. and know how to fix it please help. Soi have to go get custom piping? and how do i go on gettin the compressor and bracket sit correctly
thanks guys..
Old Jun 1, 2003 | 09:18 AM
Bontke's Avatar
Default Re: A/c With bseries swap in EF Problems (STK B16)
It is the HCP mounts. I switched from stock mounts to HCP and had the same problem. I moved the AC mount one hole up on the block and made some extensions for the bottom holes. It wasn't easy to do. Try calling HCP and see what they say to try.
Mr. Dabolina
Jan 18, 2014 08:06 PM
JokerTypeR
22
Dec 22, 2006 10:51 AM
Jesterian
14
Sep 25, 2005 06:03 PM
STK B16
Jun 2, 2003 08:24 PM
