4th gen automatic , when the sports light on the cluster is blinking...........
what does this mean? , when this happens to me, my transmission wont work, if i put it in gear it doesnt appear to be all the way in gear but it realy is , it only happens if im messng with the ignition, or messiong with the gears, its just kind of wierd and im wondering what it is.......everything is fine once i turn off the car for a moment....
just wondering what it is
fizzbob7 was your car manual before the swap??if so do you have any of your old peices from the swap??let me know wat you have because im doing a auto to manual swap on my 91 lx.
I had sort of the same problem a couple months back. My "S" start blinking also, then I noticed my speedometer not working no more. It was the speed sensor, I got that fixed, and now everything is good!!!! Hope this helps.
I think the speed sensor was around $150, but I don't remember. And I had my dads friend, which is a mechanic, fix it, and he did it for free. Took about 10 minutes. Honda said it would take around 2 hours!!!!
StupidSlowRSX
Dec 23, 2007 12:41 PM
