MPFI swap not running
Old May 31, 2003 | 10:20 PM
s520player's Avatar
Default MPFI swap not running
I put the swap in my car(d16a6), now every time I try and start it I hear click coming from a little box inside the car under the driver side of the dash. Any one no what the hell is going on with my car?
Old May 31, 2003 | 10:24 PM
1CiViC1's Avatar
Default Re: MPFI swap not running (s520player)
sounds like the clutch switch. sometimes when i dont press the pedal all the way down i get that, "clicklcikclcik" sound...
Old May 31, 2003 | 11:22 PM
civickiller's Avatar
Default Re: MPFI swap not running (1CiViC1)
whats up fellow hawaii guy, sorry no info just wanted to say hi
Old Jun 1, 2003 | 12:35 AM
1CiViC1's Avatar
Default Re: MPFI swap not running (civickiller)
well that makes three of us!! I live Mililani!
Old Jun 1, 2003 | 07:24 PM
91civicEX's Avatar
im pretty sure thats normal. sounds like its just your main relay working. it should be a click and a buzzing sounds then the buzzing stops. does your car crank?
Old Jun 1, 2003 | 10:11 PM
matt j's Avatar
Default Re: (91civicLX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicLX &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure thats normal. sounds like its just your main relay working. it should be a click and a buzzing sounds then the buzzing stops. does your car crank? </TD></TR></TABLE>
i never got that noise when i did my swap, check all grounds, power, make sure all connections are right so on and so fourth and make sure you check and recheck ALL wiring
dc2teg808
K Series
Oct 15, 2013 10:10 AM
chiboy002
Feb 19, 2010 09:43 PM
4gencivicef9
May 22, 2007 06:28 PM
RockLee`
Sep 18, 2005 06:30 PM
mr poo
13
Oct 19, 2003 07:24 PM
