Brake shim needed..
Old Jul 16, 2001 | 08:30 AM
randomwalk101's Avatar
Default Brake shim needed..
Hey I'm looking for a REAR brake shims...the little thin piece of metal between the caliber and the pad. If you're buying anotehr set of new pads from the dealer, you get a new set of shim...I got mine pads from KVR, no shim..and my old ones ripped apart. Anyways, if you replacing yours and have an old set, please let me know..i need it bad..
Old Jul 16, 2001 | 08:36 AM
Default Re: Brake shim needed.. (randomwalk101)
BTW, many thanks to Justin Edl for giving me the front ones
Old Jul 16, 2001 | 11:03 AM
ndustryalGSR's Avatar
When I put new pads on my rear brakes, I don't even think I put the shims back in . At the time, it seemed that they wouldn't fit right, or something, with the pads I bought. You'd probably be perfectly safe without them.
Old Jul 16, 2001 | 11:06 AM
Default Re: Brake shim needed.. (ndustryalGSR)
they seems to squeak a lot without the shims..right now I don't have the shim and they squeak. With the new KVR pads, i'd like to do it right
Old Jul 16, 2001 | 02:27 PM
glock's Avatar
New User
When I changed pads I never put the shims on, worked fine.
specbb6
Suspension & Brakes
Jan 8, 2013 06:28 PM
tz12789
Nov 10, 2008 09:43 AM
JohnEX
May 7, 2008 09:09 AM
PatrickGSR94
Suspension & Brakes
11
Oct 4, 2007 08:11 AM
Aphelion
Apr 23, 2005 09:20 AM
