93 teg....built bottom end...many mods $4,000
Old May 31, 2003 | 06:29 PM
mike5809's Avatar
Default 93 teg....built bottom end...many mods $4,000
Specs 1991 Integra GS. 166,000 miles. 6,500 on built motor. 5-speed. All power. Black Interior. Moon Roof. ABS. Power Windows. Etc. Car has a clean title too. Have Car-Fax report. Inspected untill Nov/03
Engine
-Compression test by mechanic on 5/28/03
-Cyl 1 = 175...Cyl 2 = 175...Cyl 3 = 173...Cyl 4 = 175...(have paper from mechanic
-1993 Bottom End
-Arias Forged Pistons 9.8:1 cr
-Shotpeened , Polished, Full Floating Rods
-Knife Edged , Micropolished Crank
-Micropolished Journals
-Rage Block Guard
-ARP Head Studs
-ARP Rod Bolts
-2000 B20Z Head milled about .020 (stock)
-DC Sport 4-2-1 ceramic header...has been polished
-Polished Valve Cover with cam side cut out.
-NGK o2 sensor (new)
Suspension and Transmission
-Exedy Stage 1 clutch (3,000 miles)
-Brembo Rotors (1,500 miles)
-Short Shifter
-Intrax 2.5in Lowering Springs
-Tockio Illumina 5-way adjustable struts
-Set of (5) 16in Sport Edition Valor Wheels (Comes with stock wheels too)
-5 Yokohama Avid H4 Tires. 2 Brand new 3 have camber wear
Body
-1993 GSR Front and Rear Bumper
-Painted Sidmoldings and Mirrors
-JDM 1-peice Headlights ...very clean (just refinished)
-Cleard Out Tails (there not good so might want to redo em or buy new ones)
-Stock Spoiler
-New paint job last year
-Amber Bumper Lenses
Misc
-Headgasket just changed 100 miles ago!!
-JVC CD player 45x4
-Polk Audio Speakers
-All new tune up parts when motor got put in
-fuel filter
-pcv valve
-belts
-etc
-Brand New Radiator (100 miles)
-New Motor Mounts
Things Wrong
-has dent in driver fender. Easy to pop out no paint chips no crease in metal...not big or noticable
-Rip in drivers seat on bolister (normal)
-AC and PS are not currently hooked up. But i can hook up before purchase (will hafta recharge AC)
This car has amazing potential. Just put motor in about 6 months ago. But i dont have time to work on it. I just picked up another job. I built it for thoughts of turbo. It is a perfect project car for turbo / high shot of nitrus / or ls-vtec.
I listed all known problems and most of the mods
I have almost all reciepts of all parts.
The bottom end cost me $2000 alone just to get built!!! (have receipts)...
[Pistons $550...head studs/rod bolts $130...block work $600...have it assembeled professionally $550...t-belt/w.pump etc $120..misc gaskets and stuff $100..and i know theres alot more...but as u can see thats well over $2000]
well i just got car back from headgasket job. turns out that wasnt whats wrong. i guess the shop that built my motor put a ring in wrong. so a ring is bad and needs replaced. if u can take a motor out it is a cheap fix...and you will have a hella good and fast car. but i dont have time to do it and not the mechanical skills.
im selling for $4,000 with wheels
$3,750 w/o them
or will consider trades for a good running car
Modified by mike5809 at 4:45 PM 6/1/2003
Modified by mike5809 at 8:23 PM 6/1/2003
Old May 31, 2003 | 06:31 PM
mike5809's Avatar
Default Re: 93 teg....built bottom end...many mods $4,000 (mike5809)
********CARFAX********
GOOD NEWS! CARFAX search results confirm this 1991 ACURA INTEGRA GS (JH4DA9366MS011337) qualifies for the FREE $5,000 CARFAX Clean Title History Guarantee. By ordering this CARFAX Report, you have significantly reduced your risk of purchasing a vehicle with a costly hidden problem.
SECTION: SECTION RESULTS:
Vehicle Specifications JH4DA9366MS011337
Title Check Clean Title History Guaranteed
Odometer Rollback Check No Odometer Rollback Detected
Problem Check No Problems Found
Registration Check Checked 7 types of vehicle registration
Vehicle History Details 7 Total Vehicle History Records Found
NOTE: This vehicle has not been inspected by CARFAX and it may have problems that have not been reported to CARFAX. CARFAX recommends a vehicle inspection by a professional mechanic.
How did CARFAX analyze this vehicle's history?
VIN: JH4DA9366MS011337
Year/Make/Model: 1991 ACURA INTEGRA GS
Body Style: HATCHBACK 2 DR
Engine: 1.8L L4 PFI DOHC 16V
Fuel: GASOLINE
Driveline: FRONT WHEEL DRIVE
Carburetion: FUEL INJECTED
Cylinders: 4
Manufactured in: JAPAN
GOOD NEWS! CARFAX search results confirm this 1991 ACURA INTEGRA GS (JH4DA9366MS011337) qualifies for the CARFAX FREE $5,000 Clean Title History Guarantee.
CARFAX analyzed this vehicle's title history to determine if any title documents were designated or marked with the following problems:
Problem Titles Checked: Results:
Salvage/Junk Checked - No Salvage/Junk Title Found
Rebuilt/Reconstructed Checked - No Rebuilt/Reconstructed Title Found
Flood Damage Checked - No Flood Damage Title Found
Damage Disclosure Checked - No Damage Disclosure Found
Manufacturer Buyback (LEMON) Checked - No Manufacturer Buyback Found
Exceeds Mechanical Limits (EML) Checked - No EML Found
Not Actual Mileage (NAM) Checked - No NAM Found
NOTE: Click here for a complete CARFAX Glossary.
GOOD NEWS! CARFAX search results on this 1991 ACURA INTEGRA GS (JH4DA9366MS011337) did not uncover a potential odometer rollback. CARFAX analyzed this vehicle's reported odometer readings to determine if any reading is less than a previously reported reading.
Date Reported: Odometer Reading:
06/27/1991 2,536
02/02/1995 21,807
06/06/2000 112,793
07/14/2000 113,779
11/02/2001 152,423
12/18/2001 152,470
12/24/2001 152,500
GOOD NEWS! CARFAX search results on this 1991 ACURA INTEGRA GS (JH4DA9366MS011337) did not uncover any of the following problems:
Problems Checked: Results:
Accident Checked - No Accident Record Found
Salvage Auction Checked - No Salvage Auction Record Found
Failed Emissions Inspection Checked - No Failed Emissions Record Found
Fire Damage Checked - No Fire Damage Record Found
Crash Test Vehicle Checked - No Crash Test Vehicle Record Found
Grey Market Vehicle Checked - No Grey Market Vehicle Record Found
CARFAX search results on this 1991 ACURA INTEGRA GS (JH4DA9366MS011337) identify the types of state motor vehicle department registrations, other than private, that appear in this vehicle's history.
Registrations Checked: Results:
Lease Checked - No Lease Registration Found
Rental Checked - No Rental Registration Found
Government Checked - No Government Registration Found
Taxi Checked - No Taxi Registration Found
Fleet Checked - No Fleet Registration Found
Commercial Checked - No Commercial Registration Found
Non-Profit Checked - No Non-Profit Registration Found
The CARFAX database contains a total of 7 vehicle history records on this 1991 ACURA INTEGRA GS (JH4DA9366MS011337):
DATE
REPORTED ODOMETER
READING INFORMATION
SOURCE GENERAL
COMMENTS
06/27/1991 2,536 West Virginia
Motor Vehicle Dept.
Morgantown, WV
Title #T441861
Title issued
02/02/1995 21,807 West Virginia
Motor Vehicle Dept.
Fairmont, WV
Title #V510029
Title issued
06/06/2000 112,793 Pennsylvania
Motor Vehicle Dept.
Chambersburg, PA
Title #54767189 01 KY
Title or registration issued
07/14/2000 113,779 Maryland
Motor Vehicle Dept.
Boonsboro, MD
Title #29736731
First lien reported
11/02/2001 152,423 Pennsylvania
Motor Vehicle Dept.
Chambersburg, PA
Title #54767189KY02
Title issued
12/18/2001 152,470 Pennsylvania
Motor Vehicle Dept.
Chambersburg, PA
Title #54767189BR03
Title issued
Ownership transfer reported
12/24/2001 152,500 Pennsylvania
Motor Vehicle Dept.
Chambersburg, PA
Title #54767189RO04
Title issued
Old Jun 1, 2003 | 08:51 AM
mike5809's Avatar
bump
Old Jun 8, 2003 | 06:40 PM
mike5809's Avatar
bump
email for more pics
Old Jun 8, 2003 | 06:49 PM
91hatchcivic's Avatar
is that cranberry/westminster mall?
Old Jun 9, 2003 | 07:00 AM
mike5809's Avatar
Default Re: (91hatchcivic)
i have no idea. it was teh mall in york, pa
riddlinkid1986
Northwest (Sales)
30
Oct 23, 2007 02:35 PM
mike5809
Sep 22, 2003 08:06 PM
mike5809
May 4, 2003 08:29 AM
mike5809
May 2, 2003 07:04 PM
