OT Grounding kits and install...
Old May 31, 2003 | 05:46 PM
SlapSmak's Avatar
Default OT Grounding kits and install...
made a grounding kit using high quality grounding wire, have some extra wire if anyone wants a set for themselves...
https://honda-tech.com/zerothread?id=521573
Modified by SlapSmak at 3:16 AM 6/1/2003
Old May 31, 2003 | 06:13 PM
B2FiNiTY's Avatar
Default Re: OT Grounding kits and install... (SlapSmak)
Link is wrong.
Old May 31, 2003 | 06:16 PM
SlapSmak's Avatar
try that
Old May 31, 2003 | 08:00 PM
machgo5go's Avatar
My friend in Japan w/EV07 GTA paid $178.00 for few ground wires from ULTRA!
Someone is getting rich out there!
Old May 31, 2003 | 10:17 PM
Tommy_Gunns's Avatar
You need to shorten some of that wire a bit to get rid of the slack (especially the valve cover to rad support wire).
Old Jun 1, 2003 | 08:26 AM
SlapSmak's Avatar
Default Re: OT Grounding kits and install... (Tommy_Gunns)
I redid some pics so you can actually see the wire. that was my first set, i plan on making that wire a little shorter.
Old Jun 1, 2003 | 08:39 AM
P1mpSlap's Avatar
I made my own. I think it helps. I noticed a smoother rev in the higher RPMs. That's about it.
Old Jun 1, 2003 | 09:47 AM
SpoonEK2's Avatar
Default Re: (P1mpSlap)
Is it okay to ground the distributor?
...Tommy Gunn's kit rocks (sorry to jack your thread).
Old Jun 1, 2003 | 02:22 PM
Blk95GSR's Avatar
Default Re: (SpoonEK2)
is there an info source on the grounding points and order they are connected in and so on?
Old Jun 1, 2003 | 02:25 PM
SlapSmak's Avatar
Default Re: (Blk95GSR)
I used the same grounding points as shown on the sun site
http://www.sunautomobile.com/
Old Jun 1, 2003 | 02:50 PM
machgo5go's Avatar
Default Re: (SlapSmak)
Gain Torque and Horsepower
(HONDA INTEGRA TYPE-R)
Are they for real?
Old Jun 1, 2003 | 03:35 PM
se93's Avatar
Where on the Sun Overseas website does it specify the grounding points? I searched the website and found nothing.
Old Jun 1, 2003 | 03:56 PM
SlapSmak's Avatar
Default Re: (se93)
there is a picture on the site which shows the cables and approx grounding points.
Old Jun 2, 2003 | 07:17 AM
SlapSmak's Avatar
still have enough for a couple more kits...
Old Jun 2, 2003 | 01:12 PM
OutLaw MR's Avatar
Dyno proven?
Old Jun 2, 2003 | 06:30 PM
SlapSmak's Avatar
Default Re: OT Grounding kits and install... (OutLaw R)
will be when i install the fields and do some pulls with and without
Old Jun 3, 2003 | 06:04 PM
ArizSun21's Avatar
From: Do I look like Michael Bolton from Office Space,, MD, USA
What points are grounded? It is kind of hard to see in the small pictures.
Old Jun 3, 2003 | 06:14 PM
SlapSmak's Avatar
Default Re: OT Grounding kits and install... (arizsun21)
Bat-trans, rad braket-valve cover, valve cover-shock tower, shock tower-intake, intake-distributor block. have not gotten on a dyno yet to tweak
Old Jun 5, 2003 | 08:56 AM
LX4CYL's Avatar
Which would be better? Intake manifold or throttle body?
Old Jun 5, 2003 | 10:44 AM
SlapSmak's Avatar
Default Re: OT Grounding kits and install... (LX4CYL)
only way to know is dyno.
jvr
Apr 11, 2014 11:56 PM
jvr
Apr 11, 2014 02:47 PM
ExVtec
Welding / Fabrication
Feb 24, 2009 01:24 PM
potatostix
Mar 31, 2006 01:27 PM
joeski
Apr 10, 2003 12:58 PM
