HyTech muffler rattle
Old May 31, 2003 | 04:59 PM
ITRJunkie's Avatar
Default HyTech muffler rattle
Just had my HyTech header + exhaust installed but the muffler is rattling against the car. Anyone else? Recommended solutions?
Old May 31, 2003 | 07:54 PM
Christian's Avatar
Default Re: HyTech muffler rattle (ITRJunkie)
yeah find the rattle and stop it
Old May 31, 2003 | 08:27 PM
TypeR 599's Avatar
Default Re: HyTech muffler rattle (Christian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Christian &raquo;</TD></TR><TR><TD CLASS="quote">yeah find the rattle and stop it </TD></TR></TABLE>
once you find it, mess with the rubber hangers holding the muffler
Old May 31, 2003 | 08:29 PM
uNF$@#!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRJunkie &raquo;</TD></TR><TR><TD CLASS="quote">Just had my HyTech header + exhaust installed but the muffler is rattling against the car. Anyone else? Recommended solutions?</TD></TR></TABLE>
check heatshields. and the rear 2 hangers, as well as the middle hangers.
Old May 31, 2003 | 10:24 PM
Austin's Avatar
Default Re: HyTech muffler rattle (Soup ****)
Mine was rattling for a little while...once it was a heat shield, and the other time it was a hanger that slipped off the car.
Old Jun 1, 2003 | 11:12 AM
ITRJunkie's Avatar
Here's a few pics... does everything look ok?
Passenger-side hanger
Driver-side hanger
And last but not least, the muffler clearance (and where I'm guessing the rattling is)
Old Jun 1, 2003 | 11:35 AM
jdmspoonitr's Avatar
That third pic is definitely your rattle, or at least one of them. Remove the heatshield and hammer it out to give the exhaust more clearance. Or you can just remove the whole thing.
Old Jun 1, 2003 | 11:38 AM
Smitdog's Avatar
Default Re: HyTech muffler rattle (jdmspoonitr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmspoonitr &raquo;</TD></TR><TR><TD CLASS="quote">That third pic is definitely your rattle, or at least one of them. Remove the heatshield and hammer it out to give the exhaust more clearance. Or you can just remove the whole thing.</TD></TR></TABLE>
That does not look like heat sheild, looks like frame........
Old Jun 1, 2003 | 11:45 AM
Eric R's Avatar
Default Re: HyTech muffler rattle (Smitdog)
There's not heat shield in that area and definitely that's his rattle problem. I'm impressed they did not offer that much clearance in that part of the exhaust...
Old Jun 1, 2003 | 12:19 PM
SMSP's Avatar
Is the tip close to the bumper? If so, why don't you try using the lower muffler hanger rods.
Old Jun 1, 2003 | 12:32 PM
sslude's Avatar
Default Re: HyTech muffler rattle (SMSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">Is the tip close to the bumper? If so, why don't you try using the lower muffler hanger rods.</TD></TR></TABLE> my thoughts exactly
Old Jun 1, 2003 | 12:59 PM
Calavera's Avatar
Default Re: HyTech muffler rattle (sslude)
yeah, if you just hang it on the black rods you should be fine.
Old Jun 2, 2003 | 08:02 AM
Austin's Avatar
Default Re: HyTech muffler rattle (Calavera)
I'll be crawling under my car later today to re-install my muffler...I'll check my clearances and see what we did differently. I know for a fact that we cut off the low part of the hangers...only the top ones are still intact.
Austin
Old Jun 2, 2003 | 08:03 AM
ragejed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Calavera &raquo;</TD></TR><TR><TD CLASS="quote">yeah, if you just hang it on the black rods you should be fine.</TD></TR></TABLE>
Because the lower rods are not hanging rods. They are there to keep the muffler in position.
Old Jun 3, 2003 | 09:05 AM
ITRJunkie's Avatar
The shop that installed everything confirmed that hanging on the lower hangers (which from the general consensus aren't actually hangers at all) would cause the muffler to hit the control arm.
The guy who's doing the install knows what's he's doing so unless someone can offer another suggestion, I'm about to let him take a hammer to the bottom of the car.
Old Jun 3, 2003 | 09:07 AM
Big Phat R's Avatar
Why don't you just get longer rubber hangers instead?
Old Jun 3, 2003 | 09:12 AM
Reid's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRJunkie &raquo;</TD></TR><TR><TD CLASS="quote">The guy who's doing the install knows what's he's doing so unless someone can offer another suggestion, I'm about to let him take a hammer to the bottom of the car. </TD></TR></TABLE>
Don't try to "clearance" your chassis.
Just get a muffler that fits properly or get longer hangers like Jonathan said.
Old Jun 3, 2003 | 09:57 AM
V-Grip! Teknic73's Avatar
Default Re: HyTech muffler rattle (Reid)
my piping rattles against my LCA, could be the same prob. i have?
Old Jun 3, 2003 | 10:06 AM
Reid's Avatar
Global Moderator
Default Re: HyTech muffler rattle (V-Grip! Teknic73)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by V-Grip! Teknic73 &raquo;</TD></TR><TR><TD CLASS="quote">my piping rattles against my LCA, could be the same prob. i have?</TD></TR></TABLE>
Are you using the proper hangers on the car?
Old Jun 3, 2003 | 10:09 AM
MaxPower's Avatar
Take it to midas and ask them nicely to stop the rattle. Probably less than $20.
Old Jun 3, 2003 | 10:12 AM
Reid's Avatar
Global Moderator
Default Re: (MaxPower)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxPower &raquo;</TD></TR><TR><TD CLASS="quote">Take it to midas and ask them nicely to stop the rattle. Probably less than $20.</TD></TR></TABLE>
This is terrible advice.
What would you expect Midas to do?
Do you realize what the problem is?
Old Jun 3, 2003 | 10:47 AM
ITRJunkie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reid &raquo;</TD></TR><TR><TD CLASS="quote">Don't try to "clearance" your chassis.
Just get a muffler that fits properly or get longer hangers like Jonathan said. </TD></TR></TABLE>
Actually, the muffler should have fit. I got a full HyTech system designed for the Type R but I guess that's the drawback of anything built-to-order (meaning minor differences are going to be a part of any hand-made product - not a problem and understandable in my book).
As suggested, where can I get some longer hangers (a link would make sure this newbie doesn't buy the wrong item)?
Old Jun 3, 2003 | 11:18 AM
ITRJunkie's Avatar
Default Re: HyTech muffler rattle (Austin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Austin &raquo;</TD></TR><TR><TD CLASS="quote">I'll be crawling under my car later today to re-install my muffler...I'll check my clearances and see what we did differently. I know for a fact that we cut off the low part of the hangers...only the top ones are still intact.
Austin</TD></TR></TABLE>
I believe this is the part that Austin cut off.
Seeing that the rubber hanger is tilted with the lower portion intact, I'm hoping that cutting it off will let it hang straight and offer the bit of clearance I need.
Thanks to everyone! Gotta love the power of H-T!
Old Jun 3, 2003 | 11:44 AM
GokuSSJ4's Avatar
make sure it has enough clearance
Old Jun 3, 2003 | 01:24 PM
Austin's Avatar
http://www.we-todd-did-racing....DE%3D
Thanks to everyone! Gotta love the power of H-T!</TD></TR></TABLE>
Yep...that's what I cut off, looking at my muffler, it appears that I have ~1/2-3/4" clearance in the area that you believe that you're rubbing.
Austin
