b16= no spark=no start???
im helpin out a friend...hes got a jdmb16 2nd gen (obd1) we cant get it to start...its wired correct but it doesnt start...we used my distributor so we know thats not the problem now....what else can it be??? there are a couple wires in the back of the block by the fuel filter that dont have a destination. we dont know if they are because the motor is obd1...you know what these wires do and if so are they needed to make the car start...2 of the wires have a big rubber boot around them and the other is a very small clip. someone please help out we wanna get this **** running...peace
Check all the grounds!! That was my problem, i forgot to hook up my thermostat ground. I had no spark or anything.
You said there is a wire with a rubber boot on the end of it.... that sounds like it could be a ground wire... Very important!! Find out what it is....
if thier is 2 plugs in one boot its the fan switch and if it is the single plug in a boot its the oil pressure sending unit plug you may need to change the coil inside the dizzy they go out often
you used a known good distributor so you know that's not the problem. The only things that it could be is your wiring to the ECU or the grounds.
he has a bad wiring harness hes going to try that maybe it will be some help...ne other suggestions? fuses are good ground are good...dizzy is good
dizzi
18
Jan 4, 2013 05:23 PM
Kentagious
Jan 17, 2007 11:40 AM
